how good are 1gen eclipse blowoff valves
Old Nov 5, 2002 | 10:34 AM
willyboyK20's Avatar
Default how good are 1gen eclipse blowoff valves
I got a dsm friend that recommended me to get one. He said something like having to "crush" it so it would hold boost better. Anyone have some experience with it. I could get it for 40 bucks and if it does the job than that leaves me with more money to spend on other parts.
ps. How do you "crush" it?
Old Nov 5, 2002 | 11:07 AM
falcongsr's Avatar
What is this crap?
Default Re: how good are 1gen eclipse blowoff valves (willyboyD16)
i used a C-clamp
takes very little force to crush it.
mine makes funny noises at part throttle. going to crush it some more and ditch it if it keeps whistling.
it seems to work just fine otherwise.
Old Nov 5, 2002 | 11:13 AM
Full-Race Javier's Avatar
Default Re: how good are 1gen eclipse blowoff valves (falconGSR)
i have one on my car, it works fine...but im only at 5psi
Old Nov 5, 2002 | 11:15 AM
CovertFI's Avatar
Default Re: how good are 1gen eclipse blowoff valves (javierb14)
40 bucks seems like a lot. i would keep looking
Old Nov 5, 2002 | 11:21 AM
falcongsr's Avatar
What is this crap?
Default Re: how good are 1gen eclipse blowoff valves (CovertFI)
true. i got a steel flange and the BOV for 35
Old Nov 5, 2002 | 11:39 AM
Tomek's Avatar
i got mine for free
Get it man its a good BOV....they hold 20psi easy in my friends dsms.
Old Nov 5, 2002 | 12:24 PM
johnisenglish's Avatar
Check this out as far as modding it so it holds higher boost http://www.thedodgegarage.com/turbo_bov_mod.html
Old Nov 5, 2002 | 01:39 PM
Pengo's Avatar
Default Re: how good are 1gen eclipse blowoff valves (johnisenglish)
cheap, works great, sounds clean
40 is a lil pricey for it but still cheaper than most bovs out there
you prob wont even need to crush it unless your gonna run large amounts of boost.
i use it and i'd recommend it. good luck
-alan
Old Nov 5, 2002 | 01:51 PM
PainfulTeg's Avatar
My friend has one on his talon running 20 psi daily driven, it's a hella better than the 2nd gen ones that are made of plastic
Old Nov 5, 2002 | 02:34 PM
pelotudo's Avatar
Default Re: how good are 1gen eclipse blowoff valves (PainfulTeg)
Awesome, best part of my whole turbo system
I love mine. Not crushed as of yet, and it sounds good. I'm thinking about crushing it just to have the higher pitched sound.
jB
Old Nov 5, 2002 | 03:25 PM
thanks for the link
Old Nov 5, 2002 | 03:36 PM
zojirushi's Avatar
mine makes a dumb whistling sound when not boosting. But sounds good when blowing off
Old Nov 5, 2002 | 03:37 PM
cjames235's Avatar
what do you do to crush it?
Old Nov 5, 2002 | 07:11 PM
Happy to help
As far as crushing goes, I'd much rather do the mod in that link, and it seems a lot more suitable for both low and high boost situations
Old Nov 5, 2002 | 08:12 PM
Pat's Avatar
Pat
sorry but noob question, in that page it mentions that the bov is open to outside air when cruising, is that true for all bovs? And so we would need to attach a filter to it?
Old Nov 6, 2002 | 12:17 PM
Default Re: how good are 1gen eclipse blowoff valves (Pat)
You don't need to attach a filter to your BOV, in fact, pretty much no one that I've seen on HT does, it's just something that can't hurt, and will maybe let you sleep a little easier at night.
Old Nov 6, 2002 | 12:19 PM
falcongsr's Avatar
What is this crap?
i am pretty sure, with my 18g turbo, that the air is always exiting the bov - not entering - at all times, even at idle.
Old Nov 6, 2002 | 01:48 PM
Supposidly at idle they open up some, even if just a little bit, and let unfiltered air into the engine. Try this - hook your BOV into a vaccum line that's getting a strong vaccum - like your engine at idle, and see if it lifts at all. Mine does a little bit past 20Hg of vaccum. But hey, maybe your's dosen't, and you're just lucky. Either way, I'm not bothering to put a filter on it
civiceg69
Mar 27, 2009 04:46 PM
Integra_drk
May 23, 2006 06:29 AM
turbojdm521
Feb 27, 2003 07:01 PM
Pengo
Aug 14, 2002 08:42 AM
