no boost WTF?!? help!
Old May 22, 2006 | 10:13 AM
Integra_drk's Avatar
Default no boost WTF?!? help!
****. i was driving home from denver yesterday and getting onto the onramp. i shifted at about 6k in 1st and was at WOT in 2nd and at about 4500 rpm i hear this loud airy noise and i lose all boost. I was like WTF? I pulled off and popped my hood. everything looked normal except that my bov was stuck open. I took it off and it popped back down. Got in the car to drive home and i still have no boost. I can hear the turbo spool but there is no boost pressure. Car drives just like it did before it was turboed. Runs fine. I have no idea why. TIA
Old May 22, 2006 | 10:16 AM
Spec R's Avatar
Default Re: no boost WTF?!? help! (Integra_drk)
your BOV probably got stuck open again, and probably has a ripped diaphragm.
Old May 22, 2006 | 10:19 AM
ek9vboi2's Avatar
Default Re: no boost WTF?!? help! (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">your BOV probably got stuck open again, and probably has a ripped diaphragm.</TD></TR></TABLE>
That or you blew a chargepipe in the process after the BOV got stuck open.
2000BoostedEX's Avatar
i agree with the above guy.. do a boost leak test to make sure its coming from there.
Old May 22, 2006 | 10:34 AM
Default Re: no boost WTF?!? help! (2000BoostedEX)
well the blow off valve is still closed. ima try to get underneath the car and check the pipes.
Old May 22, 2006 | 12:34 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">well the blow off valve is still closed. ima try to get underneath the car and check the pipes.</TD></TR></TABLE>
even if it looks like its closed a blown diaphragm wont allow the piston to open anyway.
check the charge pipes too.
Old May 23, 2006 | 03:28 AM
VTteg's Avatar
Buy a duck call from a local sporting goods store and tape it to the discharge port of your BOV then drive around. If you heard ducks when you know you shouldnt be hearing ducks, then your BOV is done for.
Old May 23, 2006 | 05:33 AM
wpgcivic's Avatar
most likely a charge pipe
Old May 23, 2006 | 06:29 AM
nota-eg's Avatar
Default Re: (wpgcivic)
Cover the opening of the BOV and drive. If it builds boost it's your BOV. If not then it's probably a charge pipe.
Check all of your couplers. That big "pop" or "boom" is usually a coupler that's come off.
EJ1 wilcox
Feb 3, 2007 10:32 PM
Nextelbuddy
Jun 12, 2004 06:39 PM
rusteds2k
Jan 7, 2004 09:33 AM
DamonBoost
Jun 4, 2003 08:36 PM
PUREVIL
May 20, 2003 09:13 PM
