ignition problems on b20 turbo/ ignition setups
Old Jun 3, 2015 | 12:29 PM
andrewdt's Avatar
Default ignition problems on b20 turbo/ ignition setups
Hi I'm having a problem, I keep blowing the stock coil on my b20/b16 head turbo. Wondering what you guys think, wanna know about everyone else's ignition setups.
Old Jun 3, 2015 | 01:32 PM
boosted94gsr's Avatar
Default Re: ignition problems on b20 turbo/ ignition setups
https://honda-tech.com/forced-induct...tions-3191479/
Good info in this thread.
Old Jun 4, 2015 | 10:59 AM
Turbo-LS's Avatar
If you keep blowing the coil you've got to have a bad wiring problem and/or ignitor issue along with that wiring problem. Start by checking and cleaning your grounds. The base wires look for anything that might have damage
Old Jun 4, 2015 | 12:17 PM
carlos8's Avatar
Turbo-LS, What CDI do you use:
SUM-850610
SUM-850611
Also in the coil:
Ps92
Ps92 E-core
Old Jun 4, 2015 | 03:28 PM
Turbo-LS's Avatar
Lx92 is a stronger coil the ps92 is older design but still a stout coil
Summit. 850610 but recently recommending the Mallory 6853m. There's been a run of defective summit boxes but still worth a shot. The limiter on the summit is 9900rpm the Mallory is good till 12k
Old Jun 4, 2015 | 09:05 PM
andrewdt's Avatar
What about the msd cap rotor and external coil, what do you guys think about that. I just out a turbo had that for like 3 weeks and didn't blow a coil and after I got a tune and hit it wot, after I turn of the car and go to re start it then it dies while I'm driving.
Old Jun 5, 2015 | 04:16 AM
Turbo-LS's Avatar
Just an external coil IMO isn't worth it. I did that years ago and had to gap the plugs down further than stock coil plus your still relaying on the ignitor to charge and fire a now larger coil. What engine management? Did they screw up the dwell settings possibly?
92lstcvc
Mar 19, 2006 07:00 AM
4inspeed
Feb 9, 2004 01:13 AM
turbo sol
May 5, 2003 06:38 AM
turb
Jan 14, 2003 12:37 AM
ITR21
Oct 15, 2002 03:13 PM
