what COIL to use?(want an external)
Old Feb 8, 2004 | 09:13 PM
4inspeed's Avatar
Default what COIL to use?(want an external)
looking for a new coil and ignition setup, would a blaster ss coil with a 6a ignition be a good setup? im running a stock for now b16a. i need a new coil anyway and instead of buying a new stock one i just want to upgrade the ignintion whether its just a coil or get the 6a ignition at the same time.
thanks.
Old Feb 8, 2004 | 09:29 PM
redzcstandardhatch's Avatar
something different
Default Re: what COIL to use?(want an external) (4inspeed)
your factory ignition is most likely more than fine for the car, but an external coil is never a really bad idea. i've been running a msd blaster2 or something like that for about 20,000 miles, with factory ignition, and its been very fine.......not a problem since i installed it over a year ago.
Old Feb 8, 2004 | 09:51 PM
4inspeed's Avatar
Default Re: what COIL to use?(want an external) (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">your factory ignition is most likely more than fine for the car, </TD></TR></TABLE>
yeah but i need to replace the coil anyway, might as well upgrade now instead of later when i get my turbo.
Old Feb 9, 2004 | 01:13 AM
Sliced Beard's Avatar
well if you are going turbo get the msd BTW you will appreciate
this ignition later on down the road
i have used this ignition on drag cars and it has always
payed off in tuning ease and reliability
budget
Apr 17, 2005 09:17 PM
Conernr1
12
Dec 3, 2004 01:16 AM
mrod006
Aug 1, 2004 09:48 PM
Blown90hatcH
Jan 10, 2003 09:11 PM
