99 civic EX - primary O2 SENSOR is missing
Old Feb 22, 2015 | 06:16 AM
N1YDP's Avatar
Default 99 civic EX - primary O2 SENSOR is missing
i have a 99 civic ex with a d16y7 engine.someone did a auto to standard swap and put a header on it but did'nt put a o2 sensor in the header.i got a sensor but i cant find the wire to plug it in.
Old Feb 22, 2015 | 06:33 AM
Former User's Avatar
Default re: 99 civic EX - primary O2 SENSOR is missing
Are you sure the primary O2 sensor is missing? The 99 Civic EX primary O2 sensor plugs into exhaust pipe A near the cat.
Old Feb 22, 2015 | 06:45 AM
N1YDP's Avatar
i will have to look.all the pictures i have seen the primary was in the manifold.i know there is one back by the shifter.they put a catback system on it to.
Old Feb 22, 2015 | 06:48 AM
The location of the stock 99 Civic EX primary sensor is as shown in the picture. Why do you think you need an O2 sensor? Is a code thrown?
The secondary sensor inserts into the cat.
Old Feb 22, 2015 | 06:54 AM
Default Re: 99 civic EX - primary O2 SENSOR is missing
You can identify the connector for primary sensor by the color of its 4 wires:
Blk/Yel, Wht, Grn/Blk, Blk/Wht
Old Feb 22, 2015 | 06:59 AM
N1YDP's Avatar
tis is what is on it minus the cat.
Old Feb 22, 2015 | 07:02 AM
N1YDP's Avatar
yes it threw a code i think it read bank1 sensor 1
Old Feb 22, 2015 | 07:10 AM
Try to locate the sensor connector in the area I mentioned.
Old Feb 22, 2015 | 08:09 AM
N1YDP's Avatar
found it.thanks.now i have to order a o2 with a female end.the one o got was a male.and to get the idle surge fixed.i amagine iac valve
Old Feb 22, 2015 | 08:11 AM
Post the exact code. Or are you saying that the primary O2 sensor is actually missing?
Old Feb 22, 2015 | 08:12 AM
Try cleaning the IACV, bleeding the cooling system, and checking for a vacuum or intake air leak. Then go from there.
Old Feb 22, 2015 | 08:17 AM
N1YDP's Avatar
the o2 is missing
Old Feb 22, 2015 | 08:19 AM
the o2 is missing
Old Feb 22, 2015 | 10:50 AM
N1YDP's Avatar
cleaned iac still does it.where they swap the transmission do you have to do something to the iac wireing
Old Feb 22, 2015 | 11:57 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Not on a Y7...unless they put a Y8 or other traditional D series style intake manifold on it at the same time.
Old Feb 22, 2015 | 12:12 PM
N1YDP's Avatar
OK thanks
thereisacat
Feb 18, 2017 09:08 AM
TurbodreamZ
Nov 28, 2009 09:05 AM
SOKDO
12
Oct 14, 2006 10:37 PM
TwistedSI
Apr 26, 2004 08:56 AM
