Will a 99 D series prim O2 fit my 99 SI????
Re: Will a 99 D series prim O2 fit my 99 SI???? (TwistedSI)
It should work. I ran 98 GSR primary and secondary o2 sensors on my 96 ex for smog and I passed emissions fine (keep in mind I live in the state of smog ****'s).
Re: Will a 99 D series prim O2 fit my 99 SI???? (powerBan.est1990)
Looking up the 99 EX primary O2 sensor the part number is 36531-P2P-A01 (Honda Code 600020). That O2 sensor only cross refrences to 99 and 00 Civic EX 2 and 4dr models only. The Civic Si primary O2 sensor part number is 36531-P2T-003 (Honda code 601826) and that fits the 99-00 Civic Si. I wouldn't recommend using the D-series O2 sensor because im pretty sure there is a big enough difference between the D-series O2 sensor and the Si O2 sensor that you may have a problem if you try to use a D-series O2 sensor. Hope this helps.
Re: Will a 99 D series prim O2 fit my 99 SI???? (vtecpower1062)
Only real difference between the two part numbers are the wires on the two o2 sensors. Otherwise they are interchangable
N1YDP
15
02-22-2015 12:12 PM
cwf1988
05-26-2008 12:58 PM
