Ball Joint into LCA
95 Honda Accord EX.
So use tightening action of nut to seat it completely or use C clamp?
Nut obviously is easier then buying/renting a tool.
Will it damage the ball joint threaded bolt via stretching the bolt?
if you have the spindle off, you can simply take a big socket the size of the ball joint and hammer it in. However their should be a c-clip that prevents it from being backed out.
Are you installing a new ball joint or did the ball joint pop out?
plaiskool
33
Aug 7, 2004 03:42 PM
