Lower ball joint
Old Sep 3, 2013 | 12:47 AM
kenzo42's Avatar
Default Lower ball joint
1) How do you know if the lower ball joint is seated in the knuckle all the way? I see a small space on mine.
2) How do you go about do it?
I overtorqued mine thinking it would help seat it, however, I'm a little worried i might have weaked the bolt and will die on the fwy.
Thanks,
Ken
Old Sep 3, 2013 | 02:56 AM
B_Swapped93's Avatar
Default Re: Lower ball joint
pic ? as long as the nut is on there along with the cotter pin you'll be safe the boot of the ball joint should sit flush with the FLCA.
Old Sep 3, 2013 | 05:38 AM
kyden's Avatar
the ball joint should be bottomed out on the knuckle.
Old Sep 3, 2013 | 07:39 AM
kenzo42's Avatar
If I overtorqued it, should I replace the ball joint? Do you think if the threads look ok, the ball joint bolt is ok?
I'm afraid to drive and have the bolt break while driving, or am I being overly cautious?
Old Sep 3, 2013 | 10:26 AM
You're being too cautions, the bolt gets over torqued at times so the cotter pin can be put in. You'll be fine monitor won't ruin the ball joint.
Old Sep 4, 2013 | 09:10 PM
grjr's Avatar
you say you over torqued the nut, were you using a torque wrench and if so what did you torque the nut to?
Old Sep 4, 2013 | 10:07 PM
ef-da-guy's Avatar
what its supposed to look like
what mine looked like
Old Sep 5, 2013 | 05:45 AM
kyden's Avatar
^^ ok? what does that have to do with this thread at all?
93(Civic)EG6
Sep 1, 2007 08:06 PM
CRseXy
13
Jan 10, 2005 10:49 PM
tuphatt
11
Sep 15, 2004 12:10 AM
plaiskool
33
Aug 7, 2004 03:42 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
