Grounded for life!
Old Jul 25, 2014 | 02:49 PM
sixstroke's Avatar
Default Grounded for life!
Alright, I've been through a lot of threads on grounding...I mean a lot...And I still haven't been able to decipher/decide on my setup.
Subject: 91 CRX Si with a b20v (b18c/b20b)
My RyWire harness had to get shipped back to the manufacturer, so I am addressing all of my grounds. I want to be grounded, like woah. This car will have a "beefy" sound system, nothing for SPL competition but I run a good amount of power to the 6.5's in the doors and the 8's in the rear.
The Plan:
Relocated battery: 0/1g feed, 0/1g ground
Valve cover to chassis: stock valve cover location to chassis - 8g
Transmission: 98 LS tranny stock ground location - 8g
Engine ground to chassis: stock location - 8g
The Confusion:
-Do I need more valve cover points grounded?
-Throttle body ground? I've read it can help improve the idlle.
-Distributor/spark ground? I've read about this for alleviating a ticking sound.
-Alternator ground?
Thank you for your input, I'm just looking to get a straight answer here. I've found so much information, so I'm likely over-thinking things at this point...
Old Jul 25, 2014 | 02:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Grounded for life!
****. Do them all.
Old Jul 25, 2014 | 05:34 PM
sixstroke's Avatar
Are they all really necessary though?
Old Jul 25, 2014 | 05:37 PM
The Grumpiest
No.
Old Jul 25, 2014 | 06:17 PM
sixstroke's Avatar
Well, while the one liner responses have been entertaining, I wouldn't mind some additional banter and discussion thrown into the mix.
For example, do any of the extra -non-factory- ground points provide any difference?
Old Jul 25, 2014 | 08:21 PM
racin_jayson's Avatar
I don't have a lot of experience with big stereos and any additional ground requirements that they may have, but I can say from experience that having the relocated batteries ground go to a solid, clean chassis ground is key, (I run mine through a kill switch on my bumper also) The ECU grounds at your thermostat housing should be super clean and tight. I also run the following grounds:
Transmission to chassis (8g)
Front of block (where old p/s bracket would be) to chassis (4G)
2x valve cover to chassis (8G)
I haven't experimented with other locations like some that you mentioned, but with this setup along with the completely new engine and ecu wire harnesses I built for my car (similar to Rywire and others), everything is perfect.
I don't think that having more grounds will ever have a negative effect, but in my experience there is no need to go overboard.
Old Jul 26, 2014 | 04:25 AM
sixstroke's Avatar
Thanks for the response Jay.
What two locations on the valve cover did you use?
Also, I have to figure out if it matters where my tstat ground goes. As my tstat has a couple locations that a ground could go. I doubt it, but ya never know.
Thanks again.
Old Jul 26, 2014 | 05:26 AM
F22Master's Avatar
The only reason that the VC needs to be grounded is to stop corrosion from.occuring. one small ground strap is plenty.
The trans ground is very important. I would go.with a 4g ground there, and you could also do a similar one some where on the timing blet side of the block. One from the cylinder head to the chassis would be good as well. That should be three solid grounding points, there should be no need to have anymore than that. And like was said above, make sure the Tstat ground is clean and tight.
Old Jul 26, 2014 | 09:14 AM
sixstroke's Avatar
Thanks for chiming in F22.
I've read that adding additional engine grounds can cause issues like killing your battery. I have nothing to support this, buy I've read it in several instances.
Old Jul 26, 2014 | 09:34 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
That would be wrong.
Old Jul 26, 2014 | 09:42 AM
That makes sense since the valve cover is electrically isolated from everything else due to all the rubber seals and grommets.
My valve cover has two identical threaded nubs on the timing belt end so I used those, but like stated above these are the least important of the grounds.
Your thermostat ground should have one short bolt that is for the ground terminal, you don't want to split your ECU grounds across different locations, doing this will run the risk of introducing voltage offsets and signal noise into your electronics circuit. Clean the aluminium housing, the bolt and the ground leads with some scotch-brite or sandpaper, and make sure that it's nice and tight.
Old Jul 26, 2014 | 09:59 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
just make sure the engine block grounds are good, especially if you have changed to a higher output alternator, if the block grounds are bad, it will try to ground through the throttle cable, or the clutch cable, and on the older cars the speedometer cable, which can ruin the cluster, also current can try to leach through the heater core, ruining it, this happens a lot of high power stereo setups, with insufficient grounds
Old Jul 27, 2014 | 11:50 AM
sixstroke's Avatar
This was my TSTAT ground, prior to cleaning. You can see where the bolt is, which is the location I was using, but there is a threaded hole right next to it as well. I really can't see it making a difference.
Old Jul 27, 2014 | 02:20 PM
valve cover studs are not isolated as they screw directly into the cam caps and are grounded through the head, which is grounded by the head studs, the one at the thermostat is important as it helps keep stray currents from trying to ground through the heater core,this causes corrosion of the core, and it eventually leaks
Old Jul 27, 2014 | 02:23 PM
if you want some really nice looking grounds, you can use the braided copper from inside TIG cables, it slides right out, cover it with clear heat shrink, you just need a good crimper for the terminals though like a rotary crimper, if you make the cables, any good electrical shop will probably do the crimps for a few bucks
Old Jul 27, 2014 | 02:25 PM
sixstroke's Avatar
Not concerned as I'm pulling the heater core all together. But, I obviously still want to be grounded properly.
How's that TSTAT spot I posted?
Old Jul 27, 2014 | 02:27 PM
just make sure the block is grounded good to the body, run the thermostat ground, and the tranny ground and you should be fine
Old Jul 27, 2014 | 02:29 PM
it's hard to tell in the pic, but one thermostat ground is before the O ring and one after, shouldnt make a huge amount of difference though as the thermostat cover is still grounded through it's bolts
shawn69
Apr 2, 2009 09:00 AM
Razr2
Oct 15, 2008 06:31 AM
LDS
Sep 25, 2007 06:02 PM
Krnbk2
May 30, 2004 06:11 AM
AutoXsi2000
Jun 21, 2002 11:13 AM
