Bad ground?
Old Mar 31, 2009 | 04:59 PM
shawn69's Avatar
Default Bad ground?
Under cranking, and cranking only, the plastic coating on the ground which connects from the valve cover to valve cover again to frame, is smoking.
So there is obviously too much current passing through that small wire, but why would this be happening?
It is highlighted in this picture.
Thanks
Old Mar 31, 2009 | 05:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Bad ground?
how good is the ground on the other side? the one from the battery to the chassis? and the one from the chassis to the tranny? if you are missing the one from the tranny to the chassis, then that will smoke the little ground you pictured there.
Old Apr 2, 2009 | 09:00 AM
shawn69's Avatar
Relocated the battery, and i didn't replace the ground...
Thanks, should be an easy fix.
Razr2
Oct 15, 2008 06:31 AM
MadCityLude
Aug 23, 2006 10:11 PM
Wazup
Sep 14, 2005 09:29 PM
User 5426
Aug 29, 2004 11:56 PM
Krnbk2
May 30, 2004 06:11 AM
