01 b20z2 into 99 Civic CX
Old Jun 23, 2014 | 09:51 AM
hafast's Avatar
Default 01 b20z2 into 99 Civic CX
I got this CRV as a rollover so I always wanted a 2.0 swap so here we go but im having problems with working with my engine harness, I have the crv engine harness but (A) plug is attached to the interior harness and its kinda against everything ive read on the forums or internet on what to do, I also have a black box that says mitsubishi on it with orange plugs that was BOLTED to the crv ecu, I know its all ABS stuff is orange, SRS is yellow but What are the Green plugs and is there a PINOUT diagram for a 01 CRV? every time I search for a pinout diagram I find VTEC ones.
Old Jun 23, 2014 | 02:15 PM
F22Master's Avatar
Default Re: 01 b20z2 into 99 Civic CX
Use all of your cars harnesses. NOT the ones from the crv
Old Jun 23, 2014 | 03:43 PM
hafast's Avatar
So swap the engine and change the ecu and it's just that easy?
Old Jun 24, 2014 | 12:52 PM
HondaPartsHero's Avatar
Technical Hero
If you use your engine harness you'll have to convert the IACV to 2 wire. Also you'll need to wire in knock sensor and use a distributor adapter. Why don't you just use the engine harness only and plug and play that way and skip all the alterations.
Old Jun 30, 2014 | 06:09 AM
hafast's Avatar
I'll try it when I get back from shambhala. Weeeeee
imsquisht
Nov 14, 2008 08:56 AM
Jamarquis
Sep 26, 2008 08:21 AM
b20beast978
23
Jun 11, 2007 09:52 AM
civic_speed99
Mar 6, 2005 07:52 PM
turkdog
Mar 7, 2003 12:27 PM
