Car wont move in gear..
Old May 26, 2014 | 02:41 PM
brandynEG's Avatar
Default Car wont move in gear..
92 eg hatch, built ls vtec, ls trans with obx lsd installed...... Doing something very odd.. When the car is running, push the clutch pedal all the way in, put it in gear, and keep the clutch pedal pushed in (as if in neutral) and the car won't roll forward or backward as if it's getting hung up on something. But it will drive in gear just fine. Also is very hard to go into/ pull out of gear. Do I just need a clutch? Never had a bad clutch do this. Just did a slave cylinder, and bled the clutch but that didn't fix it.
Old May 26, 2014 | 04:54 PM
alvarez760's Avatar
Default Re: Car wont move in gear..
Could be your clutch or pressure plate .
Old May 26, 2014 | 05:06 PM
brandynEG's Avatar
But why would that cause it to get hung up while running, in gear, with the clutch pedal pushed all the way in? It should roll as if in neutral..
Old May 26, 2014 | 05:55 PM
holmesnmanny's Avatar
the clutch isnt disengaging the input shaft .... how much free play in the clutch pedal ?
does sound like the clutch is bad
Old May 27, 2014 | 06:41 AM
brandynEG's Avatar
probably 1/3 of the whole clutch pedal movement does nothing before the clutch actually realeases/ grabs.... but all my set ups are kind of like that. normal..
Old May 27, 2014 | 08:06 AM
m4xwellmurd3r's Avatar
It could be pushing it too far and pushing the pressure plate fingers into the disc. Its more common of a problem on cable clutches but i think it can happen on hydro clutches too.
If you lift an inch off the floor is it easier?
Old May 27, 2014 | 09:00 AM
brandynEG's Avatar
Not sure.... tranny is out, putting a clutch in it.
Old May 28, 2014 | 11:23 PM
series434's Avatar
clutch not put in right or tranny syncros are messed up
Old May 29, 2014 | 01:57 AM
please update about which clutch you had in there
FeelTheBass
21
Apr 7, 2022 11:41 PM
codybb4
Dec 9, 2008 08:44 AM
Hemix
11
Jun 30, 2008 11:25 AM
dexy
Jan 11, 2005 09:53 AM
dexy
Jan 10, 2005 10:17 AM
