B20 bogging down on accel
Old May 11, 2014 | 02:52 PM
D.a.z's Avatar
Default B20 bogging down on accel
B20 ej2
Bogs down while sitting or driving
It has no cat
Hi guys I have a high comp b20 that was running absolutely fine but I had an oil leak in the dizzy so I changed the seal inside and when I fitted it back on it bogs down all the time.
I obviously thought something went wrong with the dizzy so I changed it over to my friends one that I know works fine and the same thing happend.
iv changed the engine loom aswel because it was coverd in oil from the dizzy leaking still nothing
I just can't get my head around it all I did was change the dizzy seal and now this it ran fine b4 I'm leaning towards tps or map sensor
Old May 11, 2014 | 02:57 PM
D.a.z's Avatar
Default Re: B20 bogging down on accel
I'm also using hondata s300 so I can live datalog but I don't know what I'm lookin at it
Any help is much appreciated iv searched all ova and I can find loads of threads about it but no real answers
Old May 12, 2014 | 04:02 AM
D.a.z's Avatar
Changed fuel filter,plugs and map sensor stil the same
Old May 12, 2014 | 05:07 AM
kyden's Avatar
did you check the timing after you replaced the distributor?
Old May 12, 2014 | 05:37 AM
D.a.z's Avatar
I put it in bk in the same place it came off originally but then when it wasn't working I put the other one and tried going back and forth and no matter what it still feels sort of blocked up
Old May 12, 2014 | 06:46 AM
kyden's Avatar
so.. no.
Old May 12, 2014 | 08:06 AM
Garage_Spec's Avatar
I just finished a problem similar to this, car ran fine but bogged under load, try another FPR KNOWN to work if you are still running the stock unit.
JDMswagSerf
Feb 7, 2016 02:50 PM
efkilla
Aug 28, 2014 10:09 AM
flexinb20
Dec 22, 2010 04:07 PM
si90rex
Engine Management and Tuning
May 22, 2010 10:35 AM
Hybridize
Jun 5, 2009 07:47 PM
