96 Spec Type R Compression Test
Old May 12, 2014 | 12:52 PM
HypL's Avatar
Default 96 Spec Type R Compression Test
Hey all,
I looked at a jdm type r swap for my car and compression tested it. We let the car warm up for maybe 2 minutes but the temp needle was still cold. The readings we attained were 199-201psi across all cylinders- very close to one another. I liked the consistency but these numbers seem very low for a type r. I was hoping to see numbers closer to the 230-240 mark. From your experiences does this seem to be a healthy motor and would doing the test on a fully warm engine bring more normal results? Thanks!!
Old May 12, 2014 | 01:55 PM
visiblystealthy's Avatar
Default Re: 96 Spec Type R Compression Test
I got around 190psi across all cylinders in my jdm itr motor stone cold. your numbers are good!
Old May 12, 2014 | 05:42 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Different gauges will read different numbers. You are within the "normal" range for that compression. I highly doubt you could hit the numbers you desire even right off the assembly line. Consistency is key here and it looks like you are on the mark assuming the numbers jumped to at least 50% of your final number in the first hit.
carlosp38
Mar 30, 2008 06:31 PM
YiNYaNg
12
Oct 18, 2006 04:15 AM
ITR RACER
May 24, 2004 03:09 PM
Nameless RB26
Jan 27, 2003 09:43 PM
MechEng
Feb 11, 2002 06:15 PM
