B16a2 idle fluctuate problem
Old Mar 19, 2014 | 07:09 PM
BJM3x96813's Avatar
Default B16a2 idle fluctuate problem
I've got a b16a2 engine in a 92 civic eg hatch and my idle fluctuates. It fluctuates when I come to a stop but if I turn AC on it stops. Also I cleaned IACV already still doing it. What could I turn to next?
Old Mar 20, 2014 | 08:13 AM
delsolo95's Avatar
Default Re: B16a2 idle fluctuate problem
have you tried re bleeding the coolant system and free any air bubbles trapped? or check for air leak? cels?
Old Mar 20, 2014 | 11:55 PM
BJM3x96813's Avatar
How do I bleed my coolant system? Leaks on intake hoses? Cels as in any codes?
Old Mar 21, 2014 | 03:21 AM
94_civic_dx's Avatar
i usually leave cap open while car running for about 10-15 min..are any of ur vacuum hoses leaking around the intake manifold and cels yes as in codes does the cel light come on while car is running
Old Mar 21, 2014 | 05:13 AM
Former User's Avatar
Is there an FITV attached to your throttle body?
Old Mar 22, 2014 | 07:31 PM
BJM3x96813's Avatar
I'm not sure if there is a vacuum leak I tried spraying brake clean by all the possible leak areas and idle did not go up. And yes the check engine light comes on when engine warms up.
Old Mar 22, 2014 | 07:36 PM
BJM3x96813's Avatar
I am not sure havnt looked but I will try get a picture here. If there is or isn't what should I look for?
BJM3x96813
Mar 27, 2014 07:59 PM
krysted9354
11
Mar 4, 2009 04:27 PM
85_305
15
Jan 12, 2009 05:15 PM
gotsmokedright2
Feb 20, 2004 03:13 AM
B18C-RnVA
May 12, 2002 09:15 PM
