** CONVERT from kg/cm2 to P.S.I.???? **
sup everyone i just wanted to see how acurate my boost gauge was.... my v-afc read .83 kg/cm2 at full boost.... what does that convert to in PSI??? i searched on here and on yahoo and couldnt find anything!
thanks
thanks
14.7psi or 14.5psi= 1bar? I have heard so many different answers. I go by 14.5 I've seen this more often on conversion charts.
edit:typo
[Modified by turbocoupe, 2:45 AM 10/28/2002]
edit:typo
is it on the vafc pressure measured in kg/cm2??? cause that means im at 12 psi of boost?!?!?!?!?! my boost gauge says 7 psi?!?!?!
Put it this way.. Before I got rid of my S-AFC, I used to push 1.1 bar of boost, and my S-AFC would tell me 0.72kg/cm2 - the S-AFC gets its values from the MAP sensor, and I guess the stock MAP sensor wasn't fine tuned for boost or something
why are you using a S-AFC/V-AFC anyway? Where's your standalone ECU??
yah it has to be off!! there is no way im at 11 psi or so!! and i have the vafc cause my injectors and i dont have the $$$ for zdyne or hondata! or i would!
thanks flip!!! that was what i was looking for!! it has to be wrong cause im not boosting 11.81 psi!
anyone else check their pressure on their vafc or safv and is it accurate?? maybe my map is bad?!!?
14.7 is atmospheric pressure, NOT BAR or kg/cm^2.
