bar=psi?
Old Oct 29, 2001 | 10:06 PM
InfamousRS's Avatar
Default bar=psi?
what is the ration of bar to psi?
Old Oct 29, 2001 | 10:08 PM
WykidEH's Avatar
Default Re: bar=psi? (BLK94RS)
That's a good queation. . . . I would like to know that myself. . . . any Math Professors out there?
Old Oct 29, 2001 | 10:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: bar=psi? (WykidEG6)
1Bar= 14.5psi
Mikex25's Avatar
New User
damn nm i was too slow
[Modified by Mikex25, 7:09 AM 10/30/2001]
Old Oct 29, 2001 | 10:38 PM
98hx99b18c's Avatar
Default Re: bar=psi? (Mikex25)
1 bar equals 14.5 or 14.7? I thought it was 14.7
Old Oct 29, 2001 | 11:11 PM
ken's Avatar
ken
Default Re: bar=psi? (98hx99b18c)
Its 14.5. 14.7 is atmospheric pressure.
Old Oct 29, 2001 | 11:17 PM
immortal's Avatar
Banned
Default Re: bar=psi? (SeaDawg)
and on the boost gauges....isnt it kg/cm2 or some ****? isnt that 14.22 ?
Old Oct 30, 2001 | 04:45 AM
GSRacer's Avatar
New User
Default Re: bar=psi? (immortal)
it's 14.7
Old Oct 30, 2001 | 04:46 AM
Evil DOHC's Avatar
Default Re: bar=psi? (GSRacer)
.5 bar = 7.35 psi of boost
1.0 bar = 14.70 psi of boost
EVIL
Old Oct 30, 2001 | 05:03 AM
Ubermensch's Avatar
Default Re: bar=psi? (Evil GS-R)
^ You are mistaken.
1 bar =14.503 psi
1 atm=14.695 psi
Old Oct 30, 2001 | 05:43 AM
Safir's Avatar
anothre good question kg/cm2 how many psi is that? is it the same as one bar?
Old Oct 30, 2001 | 05:56 AM
redline's Avatar
Default Re: bar=psi? (Safir)
1 kg/cm2 = 14.22psi
Old Oct 30, 2001 | 06:01 AM
Hispeed's Avatar
Default Re: bar=psi? (redline)
mayo or miracle whip??
14.5 --- 14.7 same difference j/k
Old Oct 30, 2001 | 07:16 AM
Muckman's Avatar
Moderator in Chief
ok so 14.5psi..
why have two different levels of measuring boost?
whats the deal
Old Oct 30, 2001 | 07:59 AM
GSRwBOOST's Avatar
Default Re: bar=psi? (Muckman)
one is for us metric challenged peeps and the otehr one is for the rest of the world..
Old Oct 30, 2001 | 08:02 AM
falcongsr's Avatar
What is this crap?
yes. 14.5.
inHg, mmHg, bar, psi...all developed by different people to measure the same thing.
kinda like inches and centimeters.
Old Oct 30, 2001 | 08:52 AM
98hx99b18c's Avatar
Default Re: bar=psi? (falconGSR)
The pressure ratio is the total absolute pressure produced by the turbo divided by atomspheric pressure. Absolute pressure means the amount of pressure above nothing at all. Nothing at all is zero absolute, so atomspheric is 14.7 absolute. 2 psi boost becomes 16.7 absolute, 5 psi is 19.7 absolute, and so on. Total absolute pressure is then whatever the gauge reads plus 14.7. The pressure ratio thus becomes a reflection of the number of atomspheres of pressure generated.
Pressure ratio= (14.7 + boost)/14.7
Ex: for 5 psi
PR= (14.7 + 5)/14.7 = 1.34
In this example approximately 34% more air will go into the engine than the engine could have consumed by itself.
PR= (14.7 + 12)/14.7= 1.82
Here approximately 82% more air will be going through the system. Pressure is also measured in bar, short for barometric ( 1bar=14.7 psi).
-From our friend Corky Bell
Old Oct 30, 2001 | 09:04 AM
VTC_CiViC's Avatar
Thanks 98hx, I always thought that bar itself stood for "barometric", i.e. static barometric pressure, hence 1bar is 100% atmospheric pressure, which is 14.7psi at sea level. Less at higher altitudes. So .5bar = 7.35psi being that .5 or 50% bar = 1/2 barometric/atmospheric pressure at sea level which is 14.7psi. (14.7psi x 50% = 7.35psi is the same as 1bar x .5bar = .5 bar) I know it seems confusing but reading it over leads you to see it's really easy actually.
[Modified by VTC_CiViC, 1:05 PM 10/30/2001]
Old Oct 30, 2001 | 10:16 AM
ZygSpeed's Avatar
Default Re: bar=psi? (VTC_CiViC)
OK, so how many inches (or mm of mercury) is equal to "standard" atmospheric pressure?
30" of water (or Hg i.e., mercury, I forget which) = one atmosphere (one bar, 14.7 psi) ?
Old Oct 30, 2001 | 01:07 PM
mercury's Avatar
New User
Default Relieve all your headaches here:
http://www.joshmadison.com/software/...t/download.asp
I'll bet none of you knew that so many different units existed.
Old Oct 30, 2001 | 02:19 PM
Dee's Avatar
Dee
Default Re: Relieve all your headaches here: (mercury)
why do people keep turning this into an argument? This is getting worse than the Quaife/KAAZ bumble-clot conversations. Art gave the correct answer a long time ago.
atmospheric pressure = 14.7psi
1bar = 14.5 psi
1kgcm = 14.22 psi
Old Oct 30, 2001 | 03:28 PM
liam821's Avatar
25 Year Member
Default Re: Relieve all your headaches here: (drealgsr)
I use this neat java webpage which has Bar = kg/cm2 = psi converter.
http://www.worldwidemetric.com/metcal.htm
works really well...
liam
CarAudioPro
Dec 31, 2005 11:10 AM
Supra
Jul 15, 2004 10:22 PM
boosted_zc
Jan 21, 2003 11:24 PM
EVOCELICA
May 10, 2002 01:04 PM
LS-T
Dec 13, 2001 06:32 AM
