What are these wires for???
Old Dec 5, 2013 | 02:56 PM
jdm_ek_noob's Avatar
Default What are these wires for???
I took a look around my engine today and noticed some unplugged wires. Any idea what these are for? Thanks
Oh, and where is the knock sensor located at by the way?
Old Dec 5, 2013 | 03:03 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: What are these wires for???
Manifold air temp and emmisions purge solenoid. Could also be the air intake solenoid, can't tell for sure from the pic.
The knock sensor is behind the block (firewall side) up way high near the deck where the head meets the block. One wire connector (red) most of the time.
Old Dec 5, 2013 | 03:10 PM
Marvin1985's Avatar
Top 2 are two different styles of the same sensor. Iat. Use either or. The one your holding goes into the intake pipe
Old Dec 5, 2013 | 05:00 PM
canadaek's Avatar
and the nipple on the throttle body goes to the evap canister
Old Dec 6, 2013 | 12:06 AM
crx_si-r's Avatar
Intake air temp a nd purge solenoid. It would have helped if you mentioned that you have a swapped car. Reason being why your harness doesnt plug in. Its sn ek with a b18c1 swap.
Old Dec 6, 2013 | 12:53 AM
HondaPartsHero's Avatar
Technical Hero
Looks like you're in Cali? OBD1 motor into an OBD2 car with sensors not hooked up. Good luck.
Old Dec 6, 2013 | 05:46 AM
instrument's Avatar
if I was in cali I think i'd just lease a fit...
Old Dec 6, 2013 | 08:23 AM
VeganEJ8's Avatar
http://www.ff-squad.com/tech/sensors/ks.jpg There you go
Old Dec 6, 2013 | 09:02 AM
eric26x's Avatar
Manifold air temp and intake sensor u can wire them together so no cel codes
Old Dec 6, 2013 | 10:12 AM
purgat0ry's Avatar
I'm sad the new fits are beginning to look more and more like mini-vans.
Otherwise, was this car smogged already?
Old Dec 6, 2013 | 11:30 AM
crx_si-r's Avatar
Its a gsr in an ek (ek has iat located on on factory intake pipe instead of manifold).
Easy fix is to drill a hole in the pipe and a properly sized sized grommet
jonina
18
Apr 9, 2013 08:47 PM
chrisff521
Jun 21, 2009 04:20 PM
93egboosted
Aug 1, 2008 01:01 PM
EK8D15B
Sep 8, 2007 05:39 PM
flat-blk-HB
10
Sep 28, 2002 08:22 PM
