D16Y8..a few ?'s on this motor..
Old 09-27-2002, 10:28 PM
flat-blk-HB's Avatar
Default D16Y8..a few ?'s on this motor..
Ok I have a couple as of now but I am sure I will have more..
1. Does this motor have a IAT sensor (intake air temp.)? If so where is it located? Behind the injectors? That black plug?
2. Does this motor have a Knock Sensor? If not what is the plug in the back of the block? By the oil filter?
About the knock sensor..If it has one and I dont hook it up will it run alright? I am using a P28 OBD1 ECU which does not have a knock sensor to look for..??
Old 09-28-2002, 01:17 AM
1 speedstar's Avatar
Default Re: D16Y8..a few ?'s on this motor.. (!)
1. the IAT is located on the airbox.. there should be a plug on top where the filter is.
2. im pretty sure that the motor doesn't have a knock sensor b/c i had to add the wire when doing a swap. correct me if im wrong.
HTH
Old 09-28-2002, 01:35 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: D16Y8..a few ?'s on this motor.. (p r ! m o)
Does Obd1 have a knock sensor, if not then I don't see what the problem would be since he is switching over to obd1 which I believe doesn't and obd2 does.
Old 09-28-2002, 06:52 AM
Well since you say there is a ITA sensor and it is on the airbox which I dont have..What is the best way to go around this or what will make it work?
Old 09-28-2002, 09:17 AM
ABNORMAL's Avatar
that motor does have knock sensor and no you dont need it hooked up
Old 09-28-2002, 09:25 AM
IM ALL BOB's Avatar
For the D16Y8 engine which is the SOHC VTEC motor... the IAT sensor is located at the very end of the Stock intake arm.. approx 3inches before the Arm/tube itself actually goes on ther TB
the IAT sensor on the Airbox is for the D16Y7 engine sohc non vtec..which has a vertically placed TB
and from what I RECALL I believe there is no knock sensor for the D16Y8.. though I can be mistaken.. someone correct me if I'm wrong
Old 09-28-2002, 10:29 AM
Solbros Owns Me
Evs-One's Avatar
Default Re: D16Y8..a few ?'s on this motor.. (IM ALL BOB)
no knock sensor for D series
Old 09-28-2002, 11:57 AM
EL'ation's Avatar
My car is a 98 and has a knock sensor.
This is a D16Y8 in Acura 1.6EL in Canada.
There is a possibility that civics don''t come with a knock sensor, but why would they add it just for 1.6ELs in Canada.
[Modified by EL'ation, 4:04 PM 9/28/2002]
[Modified by EL'ation, 7:19 PM 9/28/2002]
Old 09-28-2002, 12:06 PM
EL'ation's Avatar
Can you guys see the pictures?
[Modified by EL'ation, 4:07 PM 9/28/2002]
Old 09-28-2002, 01:19 PM
eg6ajk's Avatar
Default Re: D16Y8..a few ?'s on this motor.. (EL'ation)
yes 96-00 d16y8 motors used a knock sensor, while obdI d16z6/d15b sohc vtecs did not.
Old 09-28-2002, 08:22 PM
Default Re: D16Y8..a few ?'s on this motor.. (eg6ajk)
Well I got it running finally and Yes the D16Y8 has a knocks sensor on the back of the block as some of you have said...
sive
13
06-11-2013 05:23 PM
blasterman87
06-06-2010 07:04 AM
ahemming06
03-30-2006 03:31 PM
Takeoff
06-29-2003 09:24 AM
Quick Reply: D16Y8..a few ?'s on this motor..
