iat sensor in intake tubing install
Old Jun 18, 2009 | 11:14 AM
chrisff521's Avatar
Default iat sensor in intake tubing install
how do i install the iat sensor in the intake tubing?
Old Jun 18, 2009 | 01:58 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: iat sensor in intake tubing install
This must be an OBD2 engine.
Cut a hole in the intake tube about 6" from the throttle body. Use RTV or a rubber seal to keep it from leaking.
A D16Y7 IAT (if the car is a Civic) would be ideal becasue it's round and has a rubber seal.
Old Jun 19, 2009 | 11:05 AM
chrisff521's Avatar
yea its obd2 manifold so it doesnt have the iat opening. but the iat sensor wiring from the harness doesnt reach 6" from the throttle body.
Old Jun 20, 2009 | 07:35 PM
chrisff521's Avatar
is there any way i can extend the wire for iat sensor?
Old Jun 21, 2009 | 03:44 PM
Turbo B18C EJ6's Avatar
yes you can extend the wires, I did that when i changed manifolds
Old Jun 21, 2009 | 04:20 PM
xenocron's Avatar
Chris, if you can weld or have someone who can tig, you can run an OBD1 IAT, and weld this to your intake tubing.
http://www.xenocron.com/iat-flange-x...nge-p-462.html
May 21, 2009 06:02 PM
young noob
Aug 8, 2005 06:38 PM
BlendedEJ8
Oct 3, 2003 08:33 AM
SiRkid
Mar 12, 2003 10:05 AM
