Rewire fuel pump (relay getting to hot)
Old Oct 31, 2013 | 06:38 PM
carlos8's Avatar
Default Rewire fuel pump (relay getting to hot)
hi guys, Yesterday I rewire my walbro with a 30amp relay using 12ga wire.
The pump it's working excellent and the car feels awesome but i'm having a issue with the relay getting excessive hot. All is new and the wires are crimped and then solder.
This can be a Ground issue? I just put the ground to the seatbelt bolt just clean the area not grinding or sanded.
Old Oct 31, 2013 | 07:08 PM
Dominicanbulk's Avatar
Default Re: Rewire fuel pump (relay getting to hot)
Do both the ga wire match?
Old Oct 31, 2013 | 07:17 PM
carlos8's Avatar
I don't understand!!
You mean if all the wires are the same size?
If is this then YES all the wiring it's 12wga.
Old Oct 31, 2013 | 07:22 PM
Could be a bad wire. Or old wire
Old Oct 31, 2013 | 07:25 PM
Could be bad wire or old wire bro
Old Oct 31, 2013 | 07:31 PM
carlos8's Avatar
Old Oct 31, 2013 | 07:35 PM
boostlsveg's Avatar
Idk man u may want to try to file down a lil where u grounded it just to get bare metal showing. Not saying this is ur fix but it's possible it will at least help.
Old Oct 31, 2013 | 07:37 PM
Lol did you change the battery?
Old Oct 31, 2013 | 07:46 PM
Former User's Avatar
Why did you change to a 30A main relay? Why are you using an aftermarket fuel pump?
Old Oct 31, 2013 | 08:11 PM
carlos8's Avatar
I'm running a ls vtec turbo @ 17psi/ 393whp 279tq. and I was having problems with the pump voltage with some accessories turned on.
And the guys from Forced Induction recommend this.
Now the problem gone, but after 15 minutes I touched the relay and it was hot more than normally.
Old Oct 31, 2013 | 08:27 PM
Main relays get hot. That's normal.
Old Oct 31, 2013 | 08:32 PM
carlos8's Avatar
thanks!!! I go to use it tomorrow to work and see how it behaves.
mr darcko
11
Jun 20, 2012 08:25 AM
crxfreak1117
Aug 15, 2009 06:09 AM
FW_EJ8
Dec 17, 2007 06:03 PM
g2turbo
Jul 6, 2006 09:49 AM
hatchback_al
Oct 26, 2004 10:00 AM
