93 del sol bouncing idle problem plz help
I have a 93 del sol with a b20vtec (si head with jdm block) car runs fine vtec kicks no check engine light but when i turn on the head lights or the blower or the radiator fan kicks i get a bouncing idle. I replaced the grounds on the battery and in the engine bay also changed the tps and the iacv but still problem persist the car had a wire tuck when i got it so idk if maybe a wire is damaged but the car runs fine and idles fine when no electric load is added. Any info will be greatly appreciate ive searched all over and no luck
Re: 93 del sol bouncing idle problem plz help
Ok checked for vacuum leaks but their are none i swictched my ecu from my chipped p28 to a stock p72 and i no longer get the bouncing idle but now car backfires like crazy and sometimes turns off any ideas
Chandler Strom
01-19-2016 04:22 PM
98 hatchback dx
12-04-2004 10:40 AM
