Rewire fuel pump (relay getting to hot)
hi guys, Yesterday I rewire my walbro with a 30amp relay using 12ga wire.
The pump it's working excellent and the car feels awesome but i'm having a issue with the relay getting excessive hot. All is new and the wires are crimped and then solder.
This can be a Ground issue? I just put the ground to the seatbelt bolt just clean the area not grinding or sanded.
Re: Rewire fuel pump (relay getting to hot)
I don't understand!!
You mean if all the wires are the same size?
If is this then YES all the wiring it's 12wga.
Idk man u may want to try to file down a lil where u grounded it just to get bare metal showing. Not saying this is ur fix but it's possible it will at least help.
I'm running a ls vtec turbo @ 17psi/ 393whp 279tq. and I was having problems with the pump voltage with some accessories turned on.
And the guys from Forced Induction recommend this.
Now the problem gone, but after 15 minutes I touched the relay and it was hot more than normally.
g2turbo
07-06-2006 09:49 AM
hatchback_al
10-26-2004 10:00 AM
