95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
I Have a 95 honda civic ex
i have a zc block
the car start but when i accelerate it does it a bit shaky also when it is returning to idle position sometimes i will shut off sometimes it sounds like it will but does not
i have 3 check engine codes which are
code
3: map censor.
15: ignition output signal.
41: primary oxygen heater.
i have a zc block
code
3: map censor.
Chopperkiller go on YouTube and type in Honda civic map censor and you will find a video on how to check the map censor
there should be a code stamped on your Distributor ot's on one of the 3 ears the mounting bolts go through.
as long as the dissy you have mounts correctly you need the same code.
on my 97 GS-R B18C1 the code is TD-86U
on a D16Z6 the code is TD-44U
It's a zc block but the head is a 92 P08-1
It's because I swapped out the motor it had that's why am not sure because the old distributor doesn't fit it
pip9
Dec 28, 2004 02:29 PM
