100+ codes?
100+ codes?
'95 civic here at work i've been thinking about picking up to resell after fix and i hook up the scanner and prints out 125 codes.
clear them as i think its some sort of freak accident.
bam all come back on when i fire it up.
ecm/ecu problem?
any insight?
ecm/ecu problem?
any insight?
Re: 100+ codes?
it actually fires right up first crank.
runs strong, fast idle works properly no over heating.
has a brand new dizzy on it.
well i ended up saying ehhh and shipping it out.
another one slips through the fingers.
but i would still be curious how it runs so great with so many codes.
throwing multiple misfires, multiple different o2 codes, a/t codes, evap codes but still no sputtering, stalling, shaky idle nothing..
oh wells.
oh wells.
Re: 100+ codes?
With 95 civic being OBD1, and there being only 92 codes on the code list, I'm not understanding what you mean by 125+ codes. Did you jump the connector and read the CEL? Is this motor not stock? Maybe was swapped with OBD2?
Where i double checked the code list: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
