d series help! - which engine is this?
Old Apr 15, 2013 | 09:38 AM
byarbroo's Avatar
Default d series help! - which engine is this?
Can anybody tell me what d series engine this is? The engine codes have been taken off.
Last edited by deschlong; Apr 15, 2013 at 11:56 PM. Reason: Title edit to describe problem as per forum rules.
Old Apr 15, 2013 | 10:37 AM
Relington's Avatar
Default Re: d series help!
Is it running ? What kind of ecu ? Is it the original motor that came with the car ? If so run the vin
Old Apr 15, 2013 | 10:46 AM
Thecargoddess's Avatar
Sounds like the hot kinda D series if the codes were removed...
Old Apr 15, 2013 | 11:26 AM
byarbroo's Avatar
It is running, po6 ecu and I got it at a sketchy auction in the bad part of town lol.. I have no idea if its rock or not..
Old Apr 15, 2013 | 11:46 AM
94EG8's Avatar
Seagull Management
It's got a Y8 manifold on it, but it's not a Y8 engine, dipstick is between the 2nd and 3rd runners of the exhaust manifold. Check the head stamp. If it says P2J it's a Y8 head, if it says P08 it's a D16Z6/D15B Vtec head. What crank pulley? If it has the the hex hole the crank pulley holder it's probably a Z6 bottom end, if it has a series of holes around the outside it's probably a D15B7/D15B8 bottom end, although both pulleys are interchangeable. Driver's side engine mount is from a '94 - '95 VX/EX/Si model.
Old Apr 15, 2013 | 03:37 PM
DumpdEJ6's Avatar
I like the tuna here
Fckin' Honda Sherlock Holmes over here ^^^
Old Apr 15, 2013 | 06:25 PM
apexi_rsx's Avatar
does the head have a vtec solenoid on the left side of the head? if there is no vtec solenoid its a d15B7 as stated above with a y8 intake manifold.... if it does have a vtec solenoid its a D16z6 most likely. the pic is too smalll for me to see but i do see a green plug that looks like a vtec pressure switch by the dizzy.. thats a z6 valve cover for sure Vtec from the picture does not seem to be wired hence why its probbably running a p06
Old Apr 15, 2013 | 06:43 PM
94EG8's Avatar
Seagull Management
^ It's definitely got a vtec solenoid on it. You're assuming it's a complete engine, it wouldn't surprise me at all if it's a mini me of some sort. Why do I say this? It's definitely a Y8 intake manifold and the bottom end is definitely not a Y8 bottom end, see where I'm going with this? It could be a Y8 head and IM on a D15B7/D15B8/D15B2 block, or a Complete Z6 with a Y8 IM, or a Y8 head and IM on a Z6/A6 bottom end.
If I had to guess and make assumptions though I'd say it's a Z6 with a Y8 IM, based mostly on the driver's side engine mount.
Old Apr 15, 2013 | 06:56 PM
goldsy's Avatar
^^^^^ Dude knows his ****!
Old Apr 15, 2013 | 07:54 PM
apexi_rsx's Avatar
i say vtec probably isnt wired because the plug is grey and would cover up most of that green plug and it looks to be fully exposed... he is right most z6's had that aluminum mount on the drivers side....
Old Apr 15, 2013 | 11:55 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Yes, he does.
Old Apr 16, 2013 | 01:38 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: d series help! - which engine is this?
Block code
Head year code
Head code
Honda Head codes
http://www.sohchonda.com/forums/topi...es-head-codes/
Old Apr 16, 2013 | 03:53 AM
94EG8's Avatar
Seagull Management
'92 - '95 Civics and '94 - '01 Integras had a matching green plug on the harness. '96 - '00 Civics used a grey plug. Accords and Preludes used a couple of those green plugs, one for the vtec pressure switch and one for the power steering pressure switch. The pic is small enough and blurry enough that I can't tell if it's plugged in or not, if it is they definitely used a green plug though.
See pic below:
Evansouders
Jan 7, 2013 04:41 PM
TheCivicMafia
Feb 28, 2011 06:15 AM
Manny86
May 9, 2007 09:27 AM
utahbmx
May 4, 2005 02:21 PM
