What Tell Auto Tranny To Shift?
Old Sep 7, 2013 | 10:59 PM
kevinmcc2's Avatar
Default What Tell Auto Tranny To Shift?
Reason I ask is while cruising at certain speeds, for example 45 my car shifts out of 4th to 3rd constantly with steady throttle. Also at 35 it shifts into 2nd to 3rd to 2nd again.
FWIW the car is a 1998 Civic DX with about 160,000 miles on it.
Old Sep 8, 2013 | 12:25 AM
strategy400's Avatar
Default Re: What Tell Auto Tranny To Shift?
I think its all ECU for a 98. My 95 has a cable you can use to influence the shift points.
Maybe your ECU is getting bad sensor data (MAP sensor?).
Pure speculation. I think the Helm manual has a tranny troubleshooting chart/guide.
Old Sep 8, 2013 | 12:53 AM
See if this helps:
Old Sep 8, 2013 | 06:30 AM
kevinmcc2's Avatar
Hmmm Im not to sure what symtom that qualifys as.
Old Sep 8, 2013 | 06:56 AM
94EG8's Avatar
Seagull Management
If you're driving right around the speed the shift point is at this is going to happen. You can't adjust the shift points on that trans at all. It's purely electronic.
Old Sep 8, 2013 | 07:01 AM
kevinmcc2's Avatar
Hmmm, it never used to, I can understand if i was giving it more throttle, or going up a hill, but on flat ground with a steady foot it always staying in a gear.
Old Sep 8, 2013 | 07:22 AM
MRGRIM's Avatar
R.I.P. Mark
trans fluid level?
how long since the last service / fluid change
Old Sep 8, 2013 | 07:24 AM
kevinmcc2's Avatar
Originally Posted by MRGRIM
trans fluid level?
The fluid is right at the top of the full line, the fluid looks dark. I have no idea when the last service/fluid change has been. The car is new to me..from the looks of it, maybe it is the original fluid?
Old Sep 8, 2013 | 08:55 AM
Definitely change/flush that fluid, at least a few drain/refills. If it looks dark on the stick then it's really burnt or filthy. I've flushed fluid where the stick still looks pink and dark brown mud came out during the flush.
Katpwr
Jul 11, 2013 03:35 AM
redm3turbo
Jul 26, 2011 07:37 PM
rdaggett
Jun 20, 2006 10:55 AM
JMD
Oct 21, 2004 02:15 PM
KoRE
Mar 31, 2002 09:16 PM
