How do you get rid of the check engine?
Old Aug 19, 2013 | 12:28 PM
Soup Slayer's Avatar
Default How do you get rid of the check engine?
Greetings ya,ll... I hope all is well.
I'm quiet new to the honda realm, and i've recently purchased a 1998 honda civic from some random off craigslist. It's an automatic with 165k so of course it has had some problems. Recently took it to get smogged and it FAILED! due to
P0325 Knock Sensor 1 CKT malfunction and
P0135 O2 Sensor hearter fault (Bank 1 sensor 1)
I asked around and they said the car wouldn't run if the knock sensor was not working (the car runs perfect)...
Also i recently replaced the o2 sensor myself.
I was wondering how I can clear the Code
My friend tried to use an OBD2 scanner but There was an error code which I can post if that would help...
Sorry this has became lengthy, i'm just trying to pass this smog!!!!..
Old Aug 20, 2013 | 07:36 AM
Default Re: How do you get rid of the check engine?
194 views and nobody has an answer? INSANE!...
THE OBD2 Scanner had a communication error with my ECU.
I've tried leaving the negative unplugged for a length of time aswell.
I have a couple more days to get this smogged! Suggestions would be awesome!
Old Aug 20, 2013 | 09:06 AM
motoxxxman's Avatar
I'd say check the basics: all fuses, wiring damage, and clean all the ground connections in the engine bay, as well as cleaning the battery terminals and making sure they're tight
Old Aug 25, 2013 | 08:55 AM
efinimazda's Avatar
or u could remove the CEL bulb
Old Aug 26, 2013 | 02:19 AM
motoxxxman's Avatar
seriously? are you that dumb that you would suggest that? the OP failed emissions, he needs to fix whatever the issue is so he can pass emissions. the cel is there for a reason, because there's a problem. how does removing the bulb solve anything.
Old Sep 2, 2013 | 08:20 AM
efinimazda's Avatar
Hah! I'm glad you appreciate my response... once the bulb is gone the problem goes away, DUH!
Old Oct 16, 2013 | 08:28 PM
fishbol's Avatar
^This +10,000
DCWOOD
Honda Civic (2001 - 2005)
Nov 7, 2013 11:48 AM
Soup Slayer
Aug 20, 2013 08:15 AM
crx2hatch
Feb 10, 2011 06:30 AM
EG6[B16A1]
Oct 19, 2003 11:22 AM
Unsung
May 6, 2002 06:28 PM
