What dizzy do I need?
obd2 gsr
obd2 b16
can also use a obd1 with a conversion harness.
obd1= 2 plugs
obd2= 1 plug
And what makes you know your dist is about to go out? Have you had the coil or icm or anything like that test with a voltmeter? Prob just a weak link inside your current one. Might not need to replace as a whole.
obd2 b16
obd1= 2 plugs
obd2= 1 plug
I had the problem with my car turning off while I was driving and the other day it would just crank over but not start had fuel but no spark so we took the dizzy to check it out and once we put back the dizzy on the car started right back up but still continues to cut off and turn off while driving. What do you think can be causing this? Coil or icm?
i never have had to buy distributors..(please stop with the dizzy slang, we're on honda-tech, not on the corner sellin work)
just fix whats wrong with it... i keep several ICM and coils and pick ups just incase something like this happened to me.
should change the name of this site to urbanhonda-tech.com
refer to it as a dist or distributor...not the snoop doggy dizzle language snoop established years ago lol
Alright thanks for the help I might just change out the icm and see how it goes from there.. Also do u know what car model use the dist I have part number on the dizzy is td-68u
