jrsc on my gsr not boosting
Old Apr 27, 2013 | 03:56 PM
egjoseback277's Avatar
10 Year Member
Default jrsc on my gsr not boosting
what up honda tech i have a serious problem i have jrsc on my gsr motor and its not boosting i checked the bypass valve and its working fine i opened the throttle body and looked inside the supercharger and the shafts are working properly i dont noe whats wrong. Can you guys help me out with this problem
Old Apr 27, 2013 | 04:55 PM
fandsmachine's Avatar
Default Re: jrsc on my gsr not boosting
Is the belt tight? The pulley may also have come loose. Check those things. I had the same problem on my gsr.
Old Apr 27, 2013 | 05:01 PM
10 Year Member
ill check that thnks anything else i should check
Old Apr 27, 2013 | 05:04 PM
If thats not it check your gaskets. What happened exactly? Was it fine then stopped working?
Old Apr 27, 2013 | 05:08 PM
10 Year Member
i took it to get tuned by chris miller and he said its boosting 1/2 pound and i have a 6 pound pulley . he said wasnt really boosting
Old Apr 27, 2013 | 05:10 PM
10 Year Member
what gaskets should i check ? the intake manifold gasket that goes from the motor to the manifold or the one that is in the supercharger ?
Old Apr 27, 2013 | 05:11 PM
I was boosting at 3 psi and I have the same pulley. The belt became loose and once I tightened it id spike to 7 psi then settle at 6.
Both gaskets.
Old Apr 27, 2013 | 05:12 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
chris miller couldnt help you diagnosis the issue while he had the car? i find that kind of odd of a tuner not to do that, but hey everyone is different
Old Apr 27, 2013 | 05:15 PM
10 Year Member
he couldnt find the problem he was saying that the problem could be internally .
Old Apr 27, 2013 | 05:18 PM
10 Year Member
but i called jackson racing and they transfered me to another company called mossmotors and he told me what to check and i checked the bypass valve its working fine and the shafts are working properly.
Old Apr 27, 2013 | 09:44 PM
MRGRIM's Avatar
R.I.P. Mark
the bypass might look like its working
but still sounds like its open
the only things that will cause it are
leaking gaskets, charger to manifold , intake gasket, injector seals
loose belts slipping both ALT and Charger
Bypass not closing
also check the bypass to manifold conection hose for breaks / cracks
check all hose connections to manifold
hope this helps
gosu08
Apr 27, 2009 11:55 AM
wunfstgsr
Mar 3, 2009 01:02 PM
92TEGsrSC
Jan 1, 2004 07:26 PM
greekspeed
Jun 14, 2003 05:36 PM
siis2fast
Apr 21, 2003 05:04 AM
