JRSC problem
Old Apr 21, 2003 | 04:57 AM
siis2fast's Avatar
Default JRSC problem
im wondering how i can check to see if my alternator tensioner pulley is too tight or not tight enough. is there a easy way to test it out or to figure out if your in the right range for tension?
Old Apr 21, 2003 | 05:04 AM
GreddySi99's Avatar
Default Re: JRSC problem (siis2fast)
you should have about a half inch of belt deflection or figure out what you think you should be boosting. if you have a 6 psi pulley you should see 6 to 8psi if you dont try tightening the belt. one you see max boost lossen the belt just a little cause you done want them to tight. If they are to tight you run the risk of trashing the bearings in the nose drive of the charger, alt, and idler pulleys. let me know if you have any more questions. grand6000@aol.com
teamKLR.com <<<<< check us out!!
Ldo
Sep 29, 2010 09:10 AM
end005
Aug 31, 2010 06:42 PM
JDMBOLONI
Nov 13, 2004 10:41 AM
92TEGsrSC
Jan 1, 2004 07:26 PM
