head gasket?
Old Apr 6, 2013 | 05:57 PM
bvillarreal's Avatar
Icon2 head gasket?
Just wanted to be sure, bought a crv with a b20z1 cheap and I did a leak down test, pressurized cyl #4 and the air is coming out of cyl #3. Also, cyl 4 compression is 30 psi. All other cylinders are 180-200 compression. I am thinking head gasket,. Just wanted your guys opinion.
Old Apr 6, 2013 | 06:59 PM
Edgar Morales's Avatar
Default Re: head gasket?
might be the rings, if there not sealing then there wont be any compression, well thats what i know from experience but correct me if im wrong
Old Apr 7, 2013 | 06:45 PM
xile6's Avatar
With compression that low I'd say rings.
Bt pop the rad. Cap and listen for air when you do the leak down test.
Also
Old Apr 7, 2013 | 08:46 PM
EF9_TryMe's Avatar
Pour a teaspoon of oil into that low cylinder, and let the rings seal a bit.
Recheck your compression right after on that same cylinder, and see if there is a change.
If there is a change, it's most likely your rings are shot.
Old Aug 19, 2013 | 08:35 PM
wayneDOHC's Avatar
that would explain low compression, but how would the air be getting into the neighboring cyl? i ask because i am having the same problem with my gsr, but its cyl 2 leaking to cyl 1. my compression is 180 except cyl2 which is more like 135
Old Aug 22, 2013 | 09:43 PM
dude_123's Avatar
If you have access to a smog machine it's easier to check headgasket that way. Really simple, just put probe above recovery tank and rev the motor or snap throttle it. If the HC reading on the machine elevates you have urself a headgasket issue or crack head/cylinder.
Boostn B20
11
Nov 27, 2008 01:22 PM
jdmek2277
11
Sep 9, 2008 07:44 PM
MrMug3n
Jul 11, 2008 07:13 PM
thehondaguru
Jun 24, 2003 07:41 AM
bleebdat
Oct 8, 2002 03:52 AM
