HELP!!!!
Seagull Management
Re: HELP!!!! (jdmek2277)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 »</TD></TR><TR><TD CLASS="quote">could a headgasket really cause to loose compression</TD></TR></TABLE>
Yes, very yes
Yes, very yes
Re: HELP!!!! (94EG8)
how come??? changing a headgasket seems like a piece of cake rather than changing the rings....and is there a way i can make sure of what it is.....i did the compression test and when i put a cap full of oil in the cylinder the compression went to 180 does this mean its the rings....and if so is it weird jus one piston has bad rings??????
Modified by jdmek2277 at 5:47 PM 9/9/2008
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 »</TD></TR><TR><TD CLASS="quote">how come??? changing a headgasket seems like a piece of cake rather than changing the rings....</TD></TR></TABLE>
Yeah its easier, but it seems like if you blow a head gasket once they just keep blowing, bad rings you hone the cylinder, replace and thats it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek2277 »</TD></TR><TR><TD CLASS="quote">i did the compression test and when i put a cap full of oil in the cylinder the compression went to 180 does this mean its the rings....and if so is it weird jus one piston has bad rings??????</TD></TR></TABLE>
Thats probably bad rings if oil improved compression, if its just one piston its possible its possible that one piston has a stuck ring.
2fast4u831
17
08-29-2004 02:29 AM
EARLdaSQUIRREL
10
08-08-2003 02:43 PM
