Starter Rebuilding
Old Feb 23, 2006 | 05:11 PM
Touge Tuning's Avatar
Default Starter Rebuilding
Does anyone have a link on how-to rebuild/replace the starter motor contact points and what part numbers do I need to order from toyota for a starter from a MT B series.
Old Feb 24, 2006 | 08:41 AM
b20vtech's Avatar
Default Re: Starter Rebuilding (Stealth1)
my brother rebuild mines not so long ago.....he use alot of gasoline to clean the parts in there and he use alot of grease.....now it works like new.....u could almost not hear the starter when u crank it because it's so smooth......
Old Feb 24, 2006 | 08:42 AM
Default Re: Starter Rebuilding (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">my brother rebuild mines not so long ago.....he use alot of gasoline to clean the parts in there and he use alot of grease.....now it works like new.....u could almost not hear the starter when u crank it because it's so smooth...... </TD></TR></TABLE>
where did he get the parts?
Old Feb 24, 2006 | 09:52 AM
1990DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth1 &raquo;</TD></TR><TR><TD CLASS="quote">
where did he get the parts?</TD></TR></TABLE>
pm me and when i get home ill send you the part numbers. they're on my desk.
Old Feb 24, 2006 | 10:03 AM
Default Re: Starter Rebuilding (1990DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990DA &raquo;</TD></TR><TR><TD CLASS="quote">pm me and when i get home ill send you the part numbers. they're on my desk.</TD></TR></TABLE>
thanks
Old Feb 24, 2006 | 12:02 PM
found the part numbers with a bit more searching, here are the part numbers from toyota.
28226-74070
28226-64370
Old Feb 24, 2006 | 09:10 PM
here is a good article about rebuilding the starter, my only problem is there are no bolts on the end of my starter so i dont know how i can get to the 2 metal contacts inside?
http://www.4crawler.com/4x4/Ch...shtml
Old Feb 24, 2006 | 09:37 PM
K mine looks like the one below
and not like this one which im assuming is the one u guys can rebuild?
Old Feb 25, 2006 | 09:54 AM
bump
Old Feb 26, 2006 | 04:17 PM
ttt
Old Feb 26, 2006 | 07:19 PM
milton's Avatar
Default Re: (Stealth1)
i'm not too sure on this.. but my father replaced mines not too long ago.. there is a L shaped plate....
u can get these at h bros.. u have to take it apart i think... not too sure.. ill ask him.
Old Jan 6, 2013 | 03:31 AM
civic-one's Avatar
BUMP!!! back from the dead because I need to rebuild my starter and im facing the same problem as this person. My starter doesnt have those two bolts where the contacts go. How can I rebuild this. I also need to identify my starter. What kind of starter does this have but for sure its a b series because my motor is a b20.
Old Jan 6, 2013 | 11:23 PM
holmesnmanny's Avatar
larry's starter contacts http://startercontacts.com/
Old Jan 8, 2013 | 08:29 PM
Scarlet6thGen's Avatar
Not to be disrespectful but I believe that if you cannot figure out how to disassemble the starter you probably don't need to be working on the starter. They're not expensive to replace if they're worn out, and if you really want to do it right you'll replace the contacts or at least clean them, and replace the brushes, and while you're at it you might as well replace the bendix cause it's gonna go soon. But then after you've invested the time in taking the whole thing apart, you've paid for all these parts, you've put it all back together and installed it back in the car with 0 warranty... you can spend a few bucks more and buy one already assembled with a warranty. Just my $.02
Old Jan 8, 2013 | 10:40 PM
civickiller's Avatar
http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
Old Jan 9, 2013 | 07:41 PM
stumpyf4's Avatar
YouTube bitches!!
Old Aug 23, 2013 | 01:59 PM
Dekorum's Avatar
28226-74070
28226-64370
Are these just the two part numbers for the contacts and the plunger like in that video? (only Denso/Nippo brand)
What about any replacement parts for the solenoid because that tends to go bad in a lot of start failing cases.
sylvio sirame
Jun 21, 2018 09:34 AM
go2sleep
Apr 1, 2007 05:34 PM
NH538DB8
Jan 11, 2007 09:18 PM
CiViC I2aCeI2
Mar 11, 2006 04:55 PM
