B17A1 build help!!
Old Mar 31, 2013 | 04:50 PM
handafreak2112's Avatar
Default B17A1 build help!!
I have a b17a1 and was wondering if the b16b pistons will fit as far as valve clerance goes I'm using skunk 2 proseries stage 2 cams will these pistons work? With the cams?
Old Mar 31, 2013 | 07:58 PM
carlos8's Avatar
Default Re: B17A1 build help!!
they fit, always than your block and head are not milled and your builder made a clay prove. But as any R piston to fit in a b17 or b16 rod you need
to mill the rod sides. This pistons are a PITA to use in D.D. with 91 or 93 oct.
I'll recomend to you use PR3 pistons that give you a good comp. and are direct fit.
Old Mar 31, 2013 | 08:28 PM
Do you think I will have any valve clearance issues with the ctr b16b pistons ad the stage 2 pro series cams and alpha series valves?
Old Mar 31, 2013 | 08:43 PM
carlos8's Avatar
like i said before depends on the head and block been milled or not. If yor head is stock or only have a minor reshape, i don't think you have any problem. For what is your engine build to?
ex. i run a b16a with ctr (pct) piston and ctr cams with out any problems, but the block and head are stock. I build this engine 3 years ago and the
guy who i selled it still using the engine.
Old Mar 31, 2013 | 08:51 PM
I have b17 block and head , skunk alpha series valves , springs, and retainers skunk pro series stag 2 cams b16b type r pistons (ctr) stock crank stock rods , the head has been milled I think the block has too
Old Mar 31, 2013 | 09:00 PM
carlos8's Avatar
well i see you have the parts yet. My friend the only way to know is assembly
the engine and make a clay test.
and again for what is this engine Daily drive, drag race??
Because with milled head and block and those cams i will run PR3 pistons
they yield a good comp.
Old Mar 31, 2013 | 09:11 PM
Ohh and everyday and how do I (clay test) an hat r the pr3 pistons out of the b16?
Old Mar 31, 2013 | 09:14 PM
An what do the pr3 pistons have that the ctr pistons don't?
Old Mar 31, 2013 | 09:26 PM
All I am concerned about is valve clearance...
Chance EG
Apr 6, 2020 11:27 AM
shandonwall
18
May 29, 2009 05:35 AM
SupaFly_Honda
Oct 15, 2003 08:23 PM
civic1320
Jul 24, 2003 11:33 PM
McFly
Mar 2, 2003 08:01 PM
