B17A1 build help!!
I have a b17a1 and was wondering if the b16b pistons will fit as far as valve clerance goes I'm using skunk 2 proseries stage 2 cams will these pistons work? With the cams?
Re: B17A1 build help!!
they fit, always than your block and head are not milled and your builder made a clay prove. But as any R piston to fit in a b17 or b16 rod you need
to mill the rod sides. This pistons are a PITA to use in D.D. with 91 or 93 oct. I'll recomend to you use PR3 pistons that give you a good comp. and are direct fit. |
Do you think I will have any valve clearance issues with the ctr b16b pistons ad the stage 2 pro series cams and alpha series valves?
like i said before depends on the head and block been milled or not. If yor head is stock or only have a minor reshape, i don't think you have any problem. For what is your engine build to?
ex. i run a b16a with ctr (pct) piston and ctr cams with out any problems, but the block and head are stock. I build this engine 3 years ago and the guy who i selled it still using the engine. |
I have b17 block and head , skunk alpha series valves , springs, and retainers skunk pro series stag 2 cams b16b type r pistons (ctr) stock crank stock rods , the head has been milled I think the block has too
well i see you have the parts yet. My friend the only way to know is assembly
the engine and make a clay test. and again for what is this engine Daily drive, drag race?? Because with milled head and block and those cams i will run PR3 pistons they yield a good comp. |
Ohh and everyday and how do I (clay test) an hat r the pr3 pistons out of the b16?
An what do the pr3 pistons have that the ctr pistons don't?
All I am concerned about is valve clearance...
