AN fitting questions
Old Feb 25, 2013 | 11:16 AM
unspankable's Avatar
Default AN fitting questions
Hey peeps.
On the flare to npt adapters do I need crush washers on the npt side to stop leaks or will thread sealant be sufficient?
Thanks
Old Feb 25, 2013 | 11:50 AM
accorse07's Avatar
Default Re: AN fitting questions
What is the NPT side being hooked up to?
Old Feb 25, 2013 | 12:10 PM
Oil distribution block
Old Feb 25, 2013 | 12:13 PM
scmil95eg's Avatar
Doesn't matter what it's going to; NPT threads do not use o-rings or washers to seal. Pipe threads seal on themselves. Use a good thread compound and don't over-tighten (crack).
Old Feb 25, 2013 | 05:39 PM
Ok thanks!
And on the flare to accessory connections do i need crush washers? Like on the flare to fuel rail or flare to turbo oil passage?
TravisBiggie
Apr 24, 2012 08:01 PM
RTW DC2R
Sep 10, 2006 02:36 PM
aracer69
Sep 9, 2003 02:04 PM
integranator
Apr 14, 2003 10:41 PM
SI_DRIVR
Feb 4, 2003 08:11 AM
