What kind of sleeves are these?
Old Jan 30, 2013 | 02:31 PM
ceearexx's Avatar
Default What kind of sleeves are these?
I have this b18c1 block that i got free and i was just wondering if any one has an idea of what kind of sleeves these are?? they look alot like stock i was thinking darton dry sleeves?
Old Jan 30, 2013 | 04:02 PM
Natural Aspirations's Avatar
Default Re: What kind of sleeves are these?
Factory
Old Jan 30, 2013 | 04:04 PM
Loudk's Avatar
I'm not 100% sure but I'm gonna say you can't o-ring a stock sleeve. And those are o-ringed for sure. Plus stock sleeves are two toned because the iron insert is dark grey and its set into aluminum so the outer portion is actually cast aluminum. Where aftermarket sleeves are all iron.... So no aluminum casting. I'd say those r California sleeve co. Sleeves that have been o-ringed. Worth 800-1000 whp... Do it
Old Jan 30, 2013 | 04:05 PM
Loudk's Avatar
Originally Posted by Natural Aspirations
Factory
Wrong as ***!!!
Old Jan 30, 2013 | 04:08 PM
Loudk's Avatar
Outer portion on stock sleeves is all one piece that is cast with the block. Those that he has are clearly separated. It is painfully obvious for everyone to see
Old Jan 30, 2013 | 04:12 PM
91TurboGSRCRX's Avatar
Benson looks like
Old Jan 30, 2013 | 04:23 PM
tepid1's Avatar
It's a LA sleeve for sure (what Benson uses) and it's o-ringed. O-ring is either aluminum or steel. Steel o-ring should have a receiver groove in the head to work properly or be recessed far enough to make the proper impression in the head gasket yet not keep the head from properlt seating.
Old Jan 30, 2013 | 04:30 PM
B and B's Avatar
Loved
Community Favorite
Old Jan 30, 2013 | 05:09 PM
Turbo-LS's Avatar
Benson uses his own design sleeve that is manufactured by Darton. That could be benson or la sleeves
Old Jan 30, 2013 | 09:33 PM
CO_RaceFab's Avatar
those are not la sleeves... thats what most of the locals around here use and they are easy to spot. i cant tell you what they are but they arent la
dalejrfan88
Mar 6, 2012 05:46 PM
DCtooD
Jul 28, 2010 07:43 PM
Boostn B20
Aug 20, 2008 03:28 PM
mannyman2
Jan 29, 2008 09:08 PM
Sonny
Jul 15, 2002 01:34 PM
