built b81c wont start..
please help!! fresh built b18c1 turbo tunned on s300 no check engine light!! has fuel to rail and had msd external coil but just replaced it with a stock gsr dizzy that i know works... and still WILL nOT START!!! any ideas?
Engine needs three things to start: compression, fuel, spark.
In order of ease to check:
#1-Good spark at spark plugs?
#2-Fuel injectors pulsing with good fuel pressure?
#3-compression good and valve timing correct?
just put new plug new wires, replaced the msd b.s and put a stock dizzy, compression is what it was built to 9;1 it has rc 1000cc injectors and like i said i know it was getting fuel to the rail but not sure about the injectors how can i check that? just pull the rail with the injectors and turn the key?
Verify spark at the end of the spark plug wire(after removing it from the spark plug) by inserting a long screwdriver into the end and holding the screwdriver close to a good ground. Have somebody crank the engine.
To check for the injector pulse, there is a special electrical tool with a light bulb that flashes if the injectors are getting a proper signal.
http://www.beachaudio.com/Otc/7602-p...rce=ShareASale
All getting fuel at the rail tells us that the pump is working, just wont tell you if its flowing enough.
You can buy a couple tools and figure out the problem, with some help typically less than the cost of a diagnostic. If you want to learn a few things, i would go that route. If you want your car fixed in a timely manner, find the proper automotive shop.
to check if the injectors are firing:
take a long screwdriver and set the end on the injector body. place the handle up to (touching) your ear. have someone turn the key to turn the engine over. There will be an audible "click" every time the injector opens
