Need a mechanics help, Please.
Old Sep 25, 2004 | 08:51 PM
hatchdrvr's Avatar
Default Need a mechanics help, Please.
I'm helping a friend with putting a new motor in a '99 Isuzu Rodeo (Honda Passport), we have the new motor in and cannot get it to fire. The motor turns over fine, there is fuel pressure at the injectors and the injectors check out with a multi meter. We have double and triple checked cam and crank timing and fuel pressure, grounds and elec. connections. The only thing left is to check the coil packs. How do you go about checking the coil packs to make sure they're good?
Does anyone have any ideas about what the problem may be?
Old Sep 25, 2004 | 09:42 PM
GZERO's Avatar
Default Re: Need a mechanics help, Please. (hatchdrvr)
check spark at the spark plug cable, take it like 5mm away from a ground and the spark should fly, and try that for the different coil packs, it has 3, right?
Old Sep 25, 2004 | 10:31 PM
B20luda's Avatar
Default Re: Need a mechanics help, Please. (GZERO)
on the passport engine there is a coilpack for everyplug...simply remove 1 coil pack remove the spark plug put the spark plug into the coil pack like normal...make sure the coilpack is connected..then turn it over to see if u got any spark at the plug...try this on all coilpack to make sure they have them...also ck fuses make sure nothing is blowen...
Old Sep 26, 2004 | 11:19 AM
hatchdrvr's Avatar
Default Re: Need a mechanics help, Please. (B20luda)
ttt
Old Sep 27, 2004 | 02:05 PM
sugarloafpkwy's Avatar
If your injectors aren't firing and you're not getting spark then the engine may not be getting a running signal from the crank/cam sensors. I don't know where those are on this engine (It's an isuzu, right?), also check to make sure the ecu is powered. It is unlikely that all the coil packs are bad at once.
stfuek9
Engine Management and Tuning
Jan 20, 2013 07:25 PM
kondrams
Honda CR-V & Element
Dec 13, 2010 11:30 AM
j4yzn
Aug 24, 2009 12:45 PM
bleebdat
Dec 8, 2005 03:09 AM
AccordDX89
May 18, 2004 10:47 AM
