turbo b16a2 bogging before boost 0psi
Old Jan 14, 2013 | 06:09 PM
THCgt35r's Avatar
Default turbo b16a2 bogging before boost 0psi
I i have a b16a2 eagle rod wiesco pistons 9.0:1 gt35r turbo 1000cc pricicon low impedence w/ resistor box gm 3 bar MAP stock fpr tuned on crome my idle is surging an when ever i get to 0 on boost gauge it bogging and it will not go over 0 the only time it goes over 0 is on the first pull after start up i see 16psi and after vtec hit and i let off i get cell 22 and from there on no matter throttle position or gear it will not get pat 0psi any help would be appreciated.
Old Jan 14, 2013 | 06:31 PM
THCgt35r's Avatar
Default Re: turbo b16a2 bogging before boost 0psi
i had bkr7es at .030 i thought they might have been to cold so i put the 6es in there at .035 and no change i put new dizzy cap rotor and wires and no change i put 30 pounds of pressure in the many with KOEO and map read 4.7v so that is working there is no vaccume leaks and timing dead on.
Old Jan 14, 2013 | 08:09 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It is called have your car tuned.
Old Jan 14, 2013 | 08:36 PM
THCgt35r's Avatar
as stated in the previous post it is tuned on crome... but if someone else has a solution not a smart *** remark it would be helpful
Old Jan 14, 2013 | 09:15 PM
TheShodan's Avatar
Moderator
Your symptoms indicate that the program is not supplying the progressive data that it needs to. Other than any mechanical leaks that may have failed to mention. unfortunately, as "smart ***" as it is, this is more than likely the case. It may not be "CROME" (or Chrome, whatever) itself that is the issue, but a possible coruptive program.
Old Jan 15, 2013 | 12:58 AM
wantboost's Avatar
Who is Mr Robot?
Do you have a wideband? You're either running very lean or you have a fuel delivery issue.... what pump are you running?
Cel 22 is the VTEC oil pressure switch, do you have an oil pressure gauge? You might have an oil pressure issue which could be causing turbo problems, the cel, and potentially damage your motor
Old Jan 15, 2013 | 10:09 AM
THCgt35r's Avatar
I do I have a wide band when it bogs it goes rich and the car has brand new oil pump and I do I have a oil pressure gauge. its getting plenty of oil pressure. when I got it tuned my air fuels were great all around and then when it bogs it doesn't matter how much fuel was added or takin away it wont go past 0psi and rpms don't increase
Old Jan 15, 2013 | 10:39 AM
THCgt35r's Avatar
im running a 255
Old Jan 15, 2013 | 12:19 PM
wantboost's Avatar
Who is Mr Robot?
Well you clearly have a VTEC solenoid issue which means VTEC won't engage which means running rich
Replace the pressure sensor on the solenoid or the whole thing then see what happens
Can't fix anything or help you until you get that fixed
trecool44
Aug 23, 2014 02:20 PM
jonman27
Engine Management and Tuning
Oct 6, 2013 05:39 PM
lexrob
16
Mar 6, 2010 04:49 PM
welfarepc
Aug 20, 2007 06:05 PM
jammin civic
Jul 16, 2003 06:10 PM
