Another idle issue, please help
Old Jan 10, 2013 | 03:00 PM
JDM kid's Avatar
Default Another idle issue, please help
About a year ago I installed a 99 b16a2 into my 97 civic. Ever since the car has never idled correctly. Only when the car is warm and at a stop it stays at 800 then after about 10 seconds it jumps up to 1300-1500 for another 10 seconds and repeats itself. Heres a few things i've done to try to fix the problem
-Bled the coolant a few times
-Timing is dead on
-Clean IACV and replaced it with another working one.
-Tested the TPS and MAP sensors and it seems to be working properly
-Tested all around the engine for any vacuum leaks
-Cleaned the throttle body
-Triple checked all wiring and evap to make sure everything is in its correct spot.
-Calibrated the idle with evap and iacv unplugged and reset ecu.
The car does have a check engine light for a gas tank sensor which my car doesn't have and for no secondary 02 sensor, which shouldn't be the culprit of the problem at all. I am running the stock SI ecu with a obd2a-obd2b conversion harness.
Pleaseee any insight would be greatly appreciated, ive been searching google religiously to find any other info and still no luck.
Old Jan 10, 2013 | 04:36 PM
inertia_93civic's Avatar
Default Re: Another idle issue, please help
Having the same problem here.I hope we get some info on what else need to be done to fix this.Thanks in advance guys!!!
Old Jan 10, 2013 | 04:40 PM
Former User's Avatar
Test the ECT sensor and use the service manual procedure to adjust the idle speed to spec. See FAQs sticky.
Old Jan 10, 2013 | 06:49 PM
JDM kid's Avatar
I'll give it a shot tommorow. If i unplug the ECT and the idle regulates this means the sensors bad?
Old Jan 10, 2013 | 06:50 PM
Possibly
Old Jan 13, 2013 | 05:36 PM
JDM kid's Avatar
So i pulled the ECT today while the motor is warmed up and it seemed to make the idle higher and start jumping. Recently the idle has seemed to irradicate even more. When cold the car idles at 2k and hardly jumps but once its warm and say im coasting to a stop light, when i put the car in neutral before i come to a complete stop the idle will yoyo from 1k to 2k until the car is completely stopped. Once stopped the car will still idle high at 1400 but at least its steady. Checked for new engine codes and still nothing new. Any other ideas?
Old Jan 14, 2013 | 05:10 PM
JDM kid's Avatar
Well I found out today that someone installed the throttle body gasket improperly so there was a small vacuum leak that started ever since i cleaned the throttle body while it was on the car. Now the car doesnt idle so high and doesnt yoyo while coming to a stop but still has the same slow fluctuating idle while warm.
Old Jan 15, 2013 | 09:30 AM
JDM kid's Avatar
bumpp
hurleypooper
Apr 29, 2008 08:12 PM
CHK4TIX
Jan 27, 2007 05:24 PM
mikeunreal
Oct 27, 2005 02:39 PM
AcCoRdStReEtRaCeR
Jan 30, 2003 08:08 PM
maxpsi
Jan 16, 2003 12:51 PM
