What size ridge reamer is needed to get pistons out of a d15b7?
ive got a 92 civic cx with a b7 out.of a 94 dx im just wondering if anyone knows what size ridge reamer is needed to.get the pistons out? its all stock as well thanks
PHANTOM MENACE
Re: What size ridge reamer is needed to get pistons out of a d15b7?
You shouldn't need one to remove the piston. If you really really REALLY need one to remove a piston I'd imagine that block is warped far beyond the point of no return.
The piton is ~2.95 inches or 75mm so select your reamer on that.
24TEN - running a reamer around the top of a cylinder to remove carbon deposits is a common procedure in engine tear down. It doesn't mean a cylinder is warped.
PHANTOM MENACE
If that's true then I learned something new. I've done 5-6 engines and never had to use that tool ever.
It was really common on the v-8's of year long gone. With quality fuel and periodic de-carbing I could see the pistons coming straight out. Of course you could also take the piston out the bottom.
Ryhaz
15
11-03-2013 06:56 PM
rich7777
10
02-25-2010 11:58 AM
