Should I hone or bore my cylinders?
Old Nov 15, 2012 | 07:18 PM
Cap'N Chronic's Avatar
Default Should I hone or bore my cylinders?
I will be putting my car away for a while and tearing the motor out and rebuilding it. Motor is a B18B1, bone stock from what I can tell. The motor was previously boosted, and each cylinder is currently at about 140psi.
I will be putting new rings in it, and I was planning on getting a hone, but then my friend said to bore it out. I have no idea how many miles are on the motor, but it has definitely seen better days. It leaks quite a bit of oil, but doesn't burn any from what I can tell.
I am a college student on a budget, so I am trying to avoid getting new internals, which is why I am avoiding getting the cylinders bored. Any input is appreciated.
Old Nov 15, 2012 | 08:01 PM
98civdx's Avatar
Master Detailer
Default Re: Should I hone or bore my cylinders?
take it to a machine shop and have them check the block.
A min. I would hone it. you may need to bore/hone it. we can't tell you that.
Old Nov 15, 2012 | 08:23 PM
What all would I need to get parts wise if I did have to bore it?
And should I be worried about any of the bearings on the crankshaft? The motor sounds pretty solid from what I can tell.
Old Nov 15, 2012 | 08:27 PM
98civdx's Avatar
Master Detailer
You would need new pistons.
Worried as far as what?
I would probualy replace them while I was in there. but i'm really **** when it comes to stuff like this.
Old Nov 15, 2012 | 11:17 PM
Kohen's Avatar
I'd definitely replace the bearings if you're gonna rebuild it. OEM.
Old Nov 15, 2012 | 11:26 PM
jbpnoman's Avatar
Your friend who said to bore it out knows about as much regarding your motor as we do: nothing. Take the motor to a machine shop, and have them tell you if it needs to be bored, or just honed. As long as it's not warped, you should be able to get away with a good hone job.
If you're ripping apart the bottom end, it's always a good idea to go ahead and replace your rings, bearings, and seals while you're down there. Might as well get it done now while the engine is out, instead of having to pull the motor again when an old wear item finally gives out later. It all comes down to this: spend a little more money now, or a lot more money later.
Old Nov 16, 2012 | 06:14 AM
kyden's Avatar
boring depends on how out of round your cylinders are. or tapered.
Old Nov 16, 2012 | 10:40 AM
dirty19's Avatar
Ridin Dirty in Cali
rebuild after the machine shop tells you if the block is fine to reuse.
Budget yes... but its your transportation.
turbohatch96y7
Feb 21, 2013 09:16 AM
ohsnapzafingcu
13
Apr 10, 2011 06:52 PM
black_ek
Sep 26, 2007 05:29 AM
spork motorsports
14
Apr 24, 2007 07:39 AM
deSigi
Jun 8, 2004 06:50 PM
