PTW clearance
Old Feb 19, 2013 | 02:04 PM
turbohatch96y7's Avatar
Default PTW clearance
I'm looking for responses from people who have built more than one motor for accurate reply's.
Motor b18c1.
Bore 81.5mm using n50 rings.
I had the clearance at 0.0040.
Upon taking apart the motor from a burnt valve I noticed skirt wear on my cylinder walls.
So I figured ill re ring the motor and a light hone. Well upon inspecting further I noticed some wear spots were deeper. So I honed the motor till they went away. #4 cyliner and #1 had this wear that I was able to catch on my finger nail.
So I had to go to 0.0060 ptw to get these cylinders smooth. The other to are at about 0.0058
From research this gap is good for motors in the 700whp range. I'm at 400whp. Now I know this is way too big and is going to cause detonation and blow by.
I called a couple shops and I'm being told 0.0035 is where I want to be at for cp's.
I called cp and was told the same 0.0035 is the ptw I need and the skirt wear was because of being to loose at 0.0040 ptw.
I have a spare block I'm going to get bored and honed but I just want to make sure 0.0035 ptw is okay.
Question
Is 0.0035 going to make my skirts wear more than 0.0040?
What ptw is ideal for cp pistons?
If you build a motor for 700whp and have 0.0060 ptw how does it run when your not at your max power level? Lots of slap? Less miles before rebuild?
Old Feb 19, 2013 | 02:13 PM
Spawne32's Avatar
Default Re: PTW clearance
It is not wayyy to big, this is fine for the type of pistons you are using, i said that before. Blow by and leak down is going to be determined by where you set your ring gaps. So dont go overly aggressive. Remember this is only the skirt you are measuring. While .0050 probably would have been more ideal for your power range, the 2618 alloy CP pistons are going to expand to fill most of that gap regardless. As ive found from research, CP's estimates for P2W are wayyyy too tight and have always resulted in horrible skirt wear.
Old Feb 19, 2013 | 02:19 PM
Yeah I remember you saying that.
When I talked to cp they made it seem like 0.0040 was way too big. And 0.0060 was ridiculous
Old Feb 19, 2013 | 02:22 PM
I'm on the fence to either run the motor as is and learn from there. I just don't want something horrible to happen and ruin the block
Spawne32's Avatar
Do a quick forum search about piston to wall clearance and skirt wear using CP pistons, you will find a common theme among all of the users. Hell i had what CP recommended on 4031 low expansion forged pistons on my supertech's and they STILL made contact with the bore after racing. Not nearly as much as your CP's did but still expanded out far enough.
Old Feb 19, 2013 | 02:51 PM
familysedan2's Avatar
I just learned the same thing with cp today actually lol. I'm using their 10.5:1 cr pistons in my b16 build. I already have the motor assembled so I'm gonna run it and see. But my builder assured me with the p2w I would not have slap or excessive wear beyond normal.. only time will tell but I have seen a lot of his work make great results so I am gonna take his word on it
Old Feb 19, 2013 | 02:56 PM
EG1834's Avatar
Would you consider coating the pistons? I did a set to restore piston to wall clearance from .006" down to .004", and it was only like $152 through PolyDyn, but that was for 8 pistons. It's nice because it still runs like it has .004" clearance, but if something bad happens, the coating wipes away before hurting the skirt of the piston.
Old Feb 19, 2013 | 03:01 PM
What ptw are you at?
This is exactly what I started looking into. I forgot to ask laskey. About it when I had him on the phone.
What's the turn around time on that? Does the coating come in diffrent thickness? I know weisco coating has like 0.0005
Old Feb 19, 2013 | 04:17 PM
mar778c's Avatar
Community Builder
Community Influencer
OP,
Normally, with CP, I would go 0.004 for anything below 400 whp. Above that number, you need to start thinking about fuel, cams, manifold, etc. I think you are right about the clearance of 0.006 for 700 whp.
1st question, what does your set-up consist of?
Old Feb 19, 2013 | 07:05 PM
my setup is pretty basic.
cp pistons
eagle rods
stock gsr cams.
running on 91 octane.
with a to4b turbo
Old Feb 20, 2013 | 02:57 AM
mar778c's Avatar
Community Builder
I would do a couple of things in this case.
1 be a little conservative on the ring gaps.
2 make your setup a little laggy ie .82 exhaust housing
3 a bigger set of cams
4 let it warm up before you drive
Old Feb 20, 2013 | 03:16 AM
blackeg's Avatar
I think cp uses crack cocaine when the recommend ptw tolerences. They are really tight and have seen many issues including first hand when using their specs.
I like the advice that mar778c gave u. Just for the record there are/were lots of people using vitara pistons at those ptw specs and their motors ran fine. Just let it come up to temp a bit before u drive it and put load on the engine
Old Feb 20, 2013 | 03:19 AM
rich7777's Avatar
How about running a slightly higher viscosity oil ? Something like 10w50.
Old Feb 20, 2013 | 05:21 AM
[QUOTE=turbohatch96y7;48478629]What ptw are you at?
To be honest I do not remember.. I can recheck with my builder if I see him in the next couple days
Old Feb 20, 2013 | 05:48 AM
sleepencivic's Avatar
What were the conditions when the motor failed? Do you run a wideband if so what are your AFR's in boost? Can you post your timing maps? For 400 hp with CP's you should of been good at .0040... you valve could of burt the valve from a poor tune or high timing. What did the spark plug look like on the cylinder wiht the burnt valve?
Old Feb 20, 2013 | 05:50 AM
1 be a little conservative on the ring gaps. I set them at .19 top .23 bottom
2 make your setup a little laggy ie .82 exhaust housing im guessing to reduce back pressure?
3 a bigger set of cams again back pressure?
Yeah I remember your black cylinder walls lol. Im just confused why cp recommends that really tight clearance. I did find a good quote researching. " build it loose no one will know. Build it tight everybody knows"
Won't that mess with my bearing clearances at the same time?
I'm calling polydyn today and going to ask how long the coating process takes.
Old Feb 20, 2013 | 05:55 AM
The motor was tuned at 11.0 afr.
Timing I'm unsure of ill post the map when I get my battery charged.
The spark plug porcelin was cracked on that cylinder when I pulled it. No sighn of detonation besides that.
I literally got the car tuned it made it off the dyno. I babied the car for the next two days, did one pull at 13psi and that's when the valve burnt. It happened so fast I didn't get a chance to glance at the a/f gauge.
Old Feb 20, 2013 | 06:00 AM
rich7777's Avatar
It depends how tight they are. Saying that though, I ran my old stock b16 on 10w 50 for ages.
Old Feb 20, 2013 | 06:19 AM
mar778c's Avatar
Community Builder
turbohatchy96y7,
1. your ring gaps look good.
2. Yes, this will help to reduce back pressure
3. Not reduce back pressure but give you more overlap and reduce blowby.
Old Feb 20, 2013 | 07:04 AM
Gotcha thanks.
So I called poly dyn and 19 bucks a piston for skirt coatings. And 40 bucks for skirt and top coating per piston.
I should get between 0010-0014 added on the pistons.
I'm most likely sending my rods in for the coating as well. 20 bucks per rod. 4 day turn around time.
Old Feb 20, 2013 | 07:08 AM
rich7777's Avatar
Sounds good.
Old Feb 20, 2013 | 12:18 PM
Why so rich on the afr's what octane gas do you run? Was the motor ever ran not tuned or was the motor broke in (rings seated) on the dyno? When the PTW measurment was taken did you take the piston measurment below the pin in the correct spot Cp reccomends?
Old Feb 20, 2013 | 12:59 PM
Motor was broken in on my tune. I watched the af gauge and leaned it out. It idled always at 14.5 but did run sometimes really rich around 10.5 af. When the motor was put together the first time it all the measurements were taken by the nmachine shop I didn't have the tool then to double check them.
The motor is tuned now. What I'm wondering is if I should baby the car back to the dyno about 30 miles away. Or have it towed and broken in there.
I'm not sure yet.
Old Feb 21, 2013 | 09:16 AM
Muckman's Avatar
Moderator in Chief
Any peak EGT data to correlate with recommended p2w clearances?
excoupeb20jdm
Honda CR-V & Element
Feb 1, 2013 08:32 AM
Cap'N Chronic
Nov 16, 2012 10:40 AM
hondacivic995
Sep 2, 2006 08:07 PM
