97 del sol si/d16y8. check engine light.
Old Nov 11, 2012 | 02:41 PM
mish__'s Avatar
Default 97 del sol si/d16y8. check engine light.
So I installed a new radio and drove my car the next day to work... after connecting my battery back on. Everything was fine. The car sat for 2 days, then I started it up and an engine light comes on. I never had an engine light come on before. car starts up fine, drives fine, no idling issues. Nada. Did I do something? I never had this happen to me before o: cat has been changed to brand new one in january as well as o2 sensor.
Old Nov 11, 2012 | 03:30 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 97 del sol si/d16y8. check engine light.
pull the code and post
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Nov 11, 2012 | 09:49 PM
Key Enzyme's Avatar
You can always go to autozone and get it checked for free
Old Nov 12, 2012 | 01:14 AM
Technical Hero
Not if he lives in California.
Old Nov 12, 2012 | 01:21 AM
CO671's Avatar
If you don't have an OBD2 Code Reader, this trick will need only a paperclip/jumper wire:
http://www.fitfreak.net/forums/fit-d...ode-check.html
https://honda-tech.com/forums/acura-tl-rl-zdx-17/2004-tl-how-do-i-reset-my-%22check-engine%22-light-2025781/
http://www.ehow.com/how_2214653_read-obd2-codes.html
Old Nov 13, 2012 | 01:48 AM
mish__'s Avatar
So I made a video, can anyone decipher this? My coworker said I might need to clean my IACV. So I told him okay, I will, but I don't want to end up doing it, then clearing the code and have it not be the exact problem, although I noticed once I started car, the idle shot up, then went back to normal.
www.youtube.com/watch?v=T5QjZhnmF5I&feature=youtube_gdata_player
Old Nov 13, 2012 | 01:55 AM
jbpnoman's Avatar
72, 74. Random misfires in cylinders 2 and 4.
When was the last time you replaced your plugs, wires, cap, and rotor? Reset the ECU and start the car again - does either code come back?
Old Nov 13, 2012 | 02:43 AM
mish__'s Avatar
Prior owner got a new distributor put in last year, I have paperwork for that. He also got new wires and plugs for the car, but, on june/july I decided to just replace the spark plugs for the hell of it. Car CEL never came on, car was always garaged if not used. Moved into my moms and now car sits outside and the area she lives in is very cold, we're just surrounded by hills, orchards, irrigation... car sat for the 2 days I was off from work, started it up to go to work and CEL came on. Car doesn't drive crazy, car drives normal, car starts right up with just one click, but just the thought of the CEL being on irks me.
I can reset the ecu and see what happens tomorrow. Thanks.
Old Nov 13, 2012 | 02:54 AM
jbpnoman's Avatar
Since they're random misfire codes, they'll stay stored even if the problem never was really a problem. Sometimes it happens. The reset should be all you need to clear the codes - if the car is driving normally, they shouldn't come back.
jena_blondie
18
Oct 7, 2017 07:43 PM
delsolboi
Jun 3, 2013 05:09 PM
Guitarzann
Dec 13, 2005 10:21 AM
bjm01843
Feb 14, 2004 12:36 PM
Solracer
Feb 18, 2003 06:45 PM
