94 integra rs just moved from 8 to 10 psi and now its cutting off
Old Oct 28, 2012 | 05:33 AM
gary1234's Avatar
Default 94 integra rs just moved from 8 to 10 psi and now its cutting off
runs good threw first and second but when i hit the boost in third threw fifth its trying to cut off...
anyone have any ideas of what might be happening?
Old Oct 28, 2012 | 08:05 AM
ryguy2588's Avatar
Default Re: 94 integra rs just moved from 8 to 10 psi and now its cutting off
Did you get it retuned?
Old Oct 28, 2012 | 08:15 AM
vtechjunkie's Avatar
What is your spark plug gap?
Old Oct 28, 2012 | 08:26 AM
SovXietday's Avatar
This.
Old Oct 28, 2012 | 08:54 AM
95dc2teg's Avatar
Could be due to the cooler weather.
Old Oct 28, 2012 | 10:03 AM
grumblemarc's Avatar
The Grumpiest
Doubtful.
Old Oct 28, 2012 | 11:04 AM
4g hatch's Avatar
do u have a upgraded map sensor? u may have it set for 10 but u may be geting some boost creep past 10 which tha stock map sensor will not like. if you havent upgraded then you should or have a boost cut set
Old Oct 28, 2012 | 12:33 PM
JReal's Avatar
Old Oct 28, 2012 | 01:33 PM
wantboost's Avatar
Who is Mr Robot?
I'm guessing it wasn't retuned. And I bet his excuse will be but I had it tuned already
Old Oct 28, 2012 | 03:46 PM
per4mance's Avatar
boost cut??
Old Oct 28, 2012 | 04:05 PM
MalcolmV8's Avatar
Originally Posted by per4mance
boost cut??
On my S300 you can set a boost point to instantly cut power. I think it turns off the injectors if I recall. Anyhow you set it a couple PSI above what you run and if something goes wrong and you have boost creep, failed wastegate etc. it instantly shuts you down when you hit that boost level. First time I ever hit it by mistake while playing around with the boost controller feature I thought I broke the car. It instantly falls flat on its face.
It's possible the OP has upped his boost and hitting such a safety feature his tuner set.
Old Oct 28, 2012 | 04:41 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
OP is a troll!
Old Oct 28, 2012 | 04:55 PM
95dc2teg's Avatar
I meant that with the cooler weather it is more common for it to spike and hit boost cut.
Old Oct 28, 2012 | 05:28 PM
MalcolmV8's Avatar
In my limited experience if using a boost controller then most definitely. The boost controller in my S300 is based on duty cycle of the boost control solenoid. It pays no attention to what the actual boost is from the map sensor (for unknown reason) so cooler weather gets you more boost because the duty cycle stays the same. There is a temp compensator table to play with but I have yet to make adjustments there.
When running without the controller and just using a spring of set pressure I found much more consistent boost as weather changes.
Old Oct 28, 2012 | 06:58 PM
Destructive-'s Avatar
what size injectors are you running?
and like above already asked - did you retune? and what is your spark plug gap?
Old Oct 29, 2012 | 05:38 AM
scottdh20's Avatar
you tuner likely set boost cut for 11psi since thats as high as the map sensor can read. they do this for two reasons, one to protect against boost control failire, and secondly for th emoron that just cranks up the boost more than it was tuned for.
you may also be blowing out the spark which i highly dought at 10psi
Old Oct 29, 2012 | 06:32 AM
blackeg's Avatar
Originally Posted by scottdh20
you tuner likely set boost cut for 11psi since thats as high as the map sensor can read. they do this for two reasons, one to protect against boost control failure, and secondly for the moron that just cranks up the boost more than it was tuned for.
bingo!
Old Oct 29, 2012 | 05:47 PM
gary1234's Avatar
t3/t4 turbocharger 57 ar
b18b1 ls swap
3'' to 2.5 intercooler piping
2.5'' exhaust straight pipe with muffler
38mm waste gate
p28 map
660cc injectors
spark plug gap .14
and no i figured it could handle the move from 8.5 to 10 psi..
it was tuned on chrome gold by central florida turbo.
anything else?
Old Oct 29, 2012 | 07:08 PM
ryguy2588's Avatar
Retune it.
Old Oct 30, 2012 | 03:10 AM
The Grumpiest
anything else?
How'd you figure that if you had to have it tuned by a shop just to sit at 8 PSI originally?
Old Oct 30, 2012 | 08:20 AM
A BeastyDC4's Avatar
lean is fast right? haha more booost more lean moar fast!!!
Hiboost 2.0
Apr 17, 2013 08:14 PM
tundra2000
Jan 6, 2011 06:14 PM
philipwight
May 4, 2004 08:48 PM
EH2LS
Jun 5, 2003 05:53 PM
Hyper_Racer23
Mar 27, 2003 07:00 PM
