Help! Can't boost above 9PSI!!!
Old Mar 26, 2003 | 04:44 PM
Hyper_Racer23's Avatar
Default Help! Can't boost above 9PSI!!!
My setup is B18C1, sleeved, forged internals, and I'm using a Revhard stage 2c kit with Tial wastegate and Blitz SBC ID boost controller. My problem is my car will not boost above 9psi even when I set the boost controller at 12 or 14 psi. anyone have any ideas?
Old Mar 26, 2003 | 04:51 PM
Casey's Avatar
Default Re: Help! Can't boost above 9PSI!!! (Hyper_Racer23)
stock map sensor doesnt read boost over 9psi. GM 3 bar map sensor is in order
am i right? been checking out the FI forum for about 2 months after being an all motor guy. Just makin sure im learning
Old Mar 26, 2003 | 05:40 PM
echo999's Avatar
New User
Default Re: Help! Can't boost above 9PSI!!! (Casey)
Stock sensor should go to 11psi or so.
What spring do you have for the Tial? How do you have the wastegate
hooked up? I had this problem with my SBC-iD, and I ended up having
to turn it on manual mode, and slowly crank up the values until I got
the desired boost.
Old Mar 26, 2003 | 05:42 PM
bretx0r's Avatar
the boost controller must not be closing the valve at all...
Old Mar 26, 2003 | 07:09 PM
Default Re: Help! Can't boost above 9PSI!!! (bretx0r)
Well the boost controller will work fine for lower settings like say if I set it for 6psi, it'll boost 6psi. also, I set the gain to 80 and boost to 16 and still only boosts 9psi. Would my air filter have anything to do with restricting the airflow maybe? should I try to tighten my blowoff valve more? (Greddy Type-S, it's half way tightened down now)
Old Mar 26, 2003 | 07:19 PM
b16ahybrid's Avatar
Well first off the map sensor has nothing to do with how much boost your making. Even if your making 20psi of boost your stock map sensor will only function up to about 11psi (but your boost gauge will still read 20psi).
If your possitive the boost controller functions properly then you need to start looking elsewhere. If you have a dirty clogged air filter it can keep your turbo from spooling/making more boost. If your exhaust is to restrictive it will prevent you from making more boost, basically anything that prevents your turbo from doing what it likes to do best (and thats spin freely) will cause problems.
What spring is in your wg? if your say runing a .35 bar spring you may not be able to run more then 9psi or so with yout boost controller. You can only exceed the sring rating by so much... check into those things.
Old Mar 26, 2003 | 07:34 PM
bottlefedb18c1's Avatar
Default Re: Help! Can't boost above 9PSI!!! (b16ahybrid)
and check for boost leaks
Old Mar 26, 2003 | 07:38 PM
b16ahybrid's Avatar
Default Re: Help! Can't boost above 9PSI!!! (boostfedb18)
Ooops I forgot that one
Old Mar 26, 2003 | 08:09 PM
Flamenco-T's Avatar
if you're running Missing link, it won't matter, map sensor will never see boost....you can go 20 psi if you want, map sensor won't matter since missing link bleeds the boost before map sensor reads it...
check for boot leaks...
stan
Old Mar 26, 2003 | 08:30 PM
boostaholic's Avatar
Default Re: Help! Can't boost above 9PSI!!! (Flamenco-T)
What psi spring do you have in your wastegate? Unless you have a towel or something similiar as a filter it shouldn't be too restrictive, but try removing your air filter and see if it does anything. Check to see if your bov is staying open.
Old Mar 26, 2003 | 08:48 PM
accordfreak's Avatar
Default Re: Help! Can't boost above 9PSI!!! (boostaholic)
use a bike pump and check for leaks
Old Mar 26, 2003 | 09:23 PM
b16ahybrid's Avatar
I know this, the point i was making was that the map sensor has nothing to do with reading boost. Someone pointed out about the map sensor only reading 11psi of boost and that why his guage only reads 9spi..blah blah blah....
my point was map sensor has not effect on how much boost is being made.
Old Mar 26, 2003 | 10:56 PM
4dGSR at work's Avatar
try check valves... add more till you can... watch the a/f andf egt!!!!
i had a missing link and it failed after a while
Old Mar 27, 2003 | 07:00 PM
93turbolude's Avatar
a towel, thats classic!!! I was laughing for a good minute off that one!!
redlinetuning
May 7, 2009 08:41 AM
rudebwoy
Mar 17, 2007 12:53 PM
user 98292739
Aug 10, 2006 07:49 PM
GDM Z28
Nov 30, 2003 06:13 AM
Snafu-Si
Mar 5, 2002 02:07 AM
