Few nicks in they cylinder wall
Got my block and various parts back from the machine shop yesterday and I'm cleaning things up and I notice a few minor nicks the in cylinder wall. wtf. Does this mean I'm looking for a new block? They are super tiny, is this a some what common occurrence that doesn't affect anything? I've sure never seen anything like it.
Ive mostly seen that with blocks that have been sitting for some time that occur small rust spots..therefore eating away the metal. ive seen it personally with a block i sent to the machine shop and the pitting was still there when i.got it back. id say go for it
The nicks are pretty microscopic but the rings feel it. I took the top compression ring and put it in the cylinder and slid it up and down slowly and I can feel it catching slightly. Dang. I may run up to Oreillys and get a honing tool you put in your drill and run it there very lightly and see if it deburrs the few tiny nicks.
justYencedible no the machine shop is closed and I have a three day weekend. Was really hoping to build this up this weekend.
I think you will be ok, Your top ring will be below that anyways but if you nail catches I would just hone it out. You might remove like .001 so you I think you will be ok, just use a finer stone.
Wow, please, stop giving advice. Do you know how many strokes it would take to remove 0.001" ??? If he does in fact remove 0.001" to get rid of it, that is a hell of a lot. You are talking about greatly changing the piston to wall clearance. From potentially no slap to quite a bit with oil consumption.
Update. Took the block back to the machine shop this morning and he looked over the touch up I had done and he said it was fine. He said no re-honing was required as I had barely touched the top lightly and had not ruined the original hone job. So hopefully everything is good to go.
Ok, where is the reasoning or experience other then it may "look" like a bad solution.
Yeah those responses worried me enough to take the block back to the machine shop. Granted I barely touched the cylinder and can't say for sure what additional usage may have done.
It is called inexperienced people that have no clue what they are talking about. They don't know how to use the tool properly and don't have the correct skill set to attempt it. We have been using those types of hones for DECADES... sure there are much better solutions now that remove any skill that is needed, but in the right hands that style of hone is perfectly fine.
Im just curious! are you that anxious to put the motor in?
I mean for one its a rebuilt block, you might void any warranty by doing that to the motor in the event you have issue with the block! the machinist might simply say "well you re honed it after i worked on it so i really don't know what you did after i worked on it therefor your warranty is null.
But i would of deff just took it back to him that day! i mean you paid him all that money just to take it home and look at it and say "i dont think it was done right let me touch it up a little bit"!
If he has assured you those will not affect the motors performance then you should be good GL.
Couldn't care less about warranty. It was $20 per cylinder to bore and hone. Worse case he said I owed him another $20 to rehone that cylinder. I figured he wouldn't though as I've brought him quite a bit of work over the years, great guy to work with and yes he said the cylinder is just fine.
Apex i ITR
Aug 12, 2002 01:34 PM
