Hondata / Ecu Tuning on a stock R?
Old Oct 16, 2002 | 09:13 AM
Philly_NBP_R's Avatar
Default Hondata / Ecu Tuning on a stock R?
Hey all you gurus... got a quick question.
Would there be any significant gains using a Hondata s200 system on a relatively stock 01 R ?? Reasons for this question... I like the stock drivability and clean emissions, but am interested in how much power can be gained from ecu tuning. I realize that the stock exhaust (header, cat) is a restriction, so this will have to be addressed, but would a Hondata system be a logical first step?
(I'm a bit of a computer geek, and like the idea of plugging a laptop in, tuning, and datalogging )
TIA
Old Oct 16, 2002 | 09:21 AM
JPP's Avatar
JPP
Default Re: Hondata / Ecu Tuning on a stock R? (Philly_NBP_R)
With adjustable camgears, programmable ECU and a little "blue printing" I beleive a stock engine could reach around 175 whp.
Old Oct 16, 2002 | 09:33 AM
sgT's Avatar
sgT
Default Re: Hondata / Ecu Tuning on a stock R? (JPP)
warren is almost at 190whp with stock cam gears, stock ecu and stock blueprinted motor.
Old Oct 16, 2002 | 09:58 AM
RagingAngel's Avatar
Default Re: Hondata / Ecu Tuning on a stock R? (sgT)
mrmmm....
I'm wondering if his header has anything to do with the power gains? ahhaa...
Old Oct 16, 2002 | 10:29 AM
vtec.dc2's Avatar
I got that without cam gears or blue printing.. just tuning comptech box/filter/jdm4-1/2.5 cat and exhaust
car accelerates great.. hp gains are everywhere..
not worth the money on stock header/cat... get that first.. then tune it
Old Oct 16, 2002 | 10:43 AM
JPP's Avatar
JPP
Well I was a little hesitant to throw high numbers around simply because of variance in testing equipment. I mean I have seen dyno plot of stock ITR showing 170-175 whp and other 155-160 whp. Maybe I should of said " possible gain of around 25 whp compare to stock".
Old Oct 16, 2002 | 10:45 AM
sgT's Avatar
sgT
its amazing what blueprinting can do
Old Oct 16, 2002 | 10:51 AM
JPP's Avatar
JPP
Ooohhh yes...but sometimes a little $$.
Old Oct 16, 2002 | 10:53 AM
sgT's Avatar
sgT
but if you already have to take it apart........
Old Oct 16, 2002 | 10:58 AM
JPP's Avatar
JPP
Yes, yes... now all you need is a table full of parts and find the ones with the proper tolerances
Old Oct 16, 2002 | 11:29 AM
thanks for the replys... just as I thought
the header/cat/exhaust first, then ecu tuning....
then cams?
then injectors...
then BOOST
hahaha
all in due time I guess.
Old Oct 16, 2002 | 11:42 AM
JPP's Avatar
JPP
then cams?
then injectors...
then BOOST
hahaha
Actually it should be:
Header/cat/exhaust (no real tuning needed)
Camgears
Then tunning
...**** not enought power...
camshaftss / valve train / injectors
More tuning
...fu$% still not enought...
higher compression
More tuning
...could be better...
Final drive / flywheel
...Ok now we are getting there...
Etc, etc...Have fun
slippery seal
Honda Civic (2016 - Current)
Aug 30, 2017 03:50 AM
99lspwr
Engine Management and Tuning
Oct 11, 2013 12:33 PM
TurboGS-R
May 31, 2006 03:11 PM
inzane
Nov 24, 2005 10:38 AM
95turbogsr
Jun 26, 2005 09:17 AM
